Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 77
Thread: Project Mk5 GTI Android head unit WIP
  1. #61
    Jul 2013
    Adelaide, Australia
    Has anyone with factory reverse sensors got an android head unit and confirmed the sensors work?
  2. #62
    Nov 2013
    Queensland
    Have factory reverse sensors and they work fine. But If you're referring to ops, can't help you there, my jetta didn't come with ops
    Sent from my Nexus 5 using Tapatalk
  3. #63
    Dec 2012
    Okay probably stupid questions but here goes...
    1. Has anyone got one of these hooked up to a rvc yet and if so, is it any good?
    2. I have factory bluetooth (thingy under my seat). I assume this unit couldnt be integrated as it seems to have its own bluetooth... meaning my bluetooth is redundant right...?
    Sent from my SM-T310 using Tapatalk
  4. #64
    Jul 2013
    Adelaide, Australia
    Quote Originally Posted by chanjmc View Post
    so when you put the car into reverse gear, the android head unit will display the beep and visual closing range thingy?
  5. #65
    Nov 2013
    Queensland
    Quote Originally Posted by staryknight View Post
    Sounds like you're referring to OPS (optical parking system) in which case I don't not have. I just have the standard reverse sensors that came with mk5 jettas, so they beep fine when in reverse.
    Have hooked up rvc, but need to add a capacitor to keep the current constant. Will update when I get around to it...
  6. #66
    Yes your factory bt will not connect to this unit. You use the inferior inbuilt one.
    Cheap rvc works well. Fast switch on selecting reverse.
    Sent from my HTC One using Tapatalk
  7. #67
    Nov 2013
    Queensland
    Kamold, have you been able to keep your unit on even after ignition on (key in) like how the stock units used to? I've only been able to manage a few minutes on my unit before it powers itself off. I've even set the acc shut down timer to 30min and still does the same thing.
  8. #68
    It stays on, but screen turns off. To keep it fully on you need to be on ACC. But at least if you go to pay for fuel or whatever you don't need to wait for boot.
  9. #69
    I installed Neutron music player, much better than the stock player. N7player is good also but Neutron interface is a bit chunkier which suits car usage.
  10. #70
    Feb 2010
    brisbane, QLD
    Help please! I've just ripped out the old rcd 300 and connected up the android unit but cannot get power on. I've checked all connections multiple times but can't work it out. Is there a step by step guide somewhere (I've searched but have been unable to find anything).
