Thanks for the advice, gents.
I went shopping and found that the Fusion 10" powered sub was too cheap to pass up. $199 for an amp, sub and box already built, with everything needed to fit it - cables, fuses, straps. It was hard to buy separates for that much.
I fitted it in about 2 hours, running the power cable through the front wing and under the trim on the sill. RCA, control and remote leads went through the centre console and under the carpet between the rear seats. All I need to do now is fix the bass adjuster under the dash.
Only problem is that I no longer have a 12v supply while the key is in the ignition. Maybe because I disconnected the battery and something needs to be reset?
1997 Lotus Elise S1
Fiesta
2012 Triumph Tiger 800 XC
