Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Post your system!
  1. #21
    Gosford Central Coast NSW
    Pioneer CD tuner (i hate the term head unit)
    Pioneer GS 6.5" 3way fronts
    6x9's in rear and 10" sub with JVC amp
    fully sick mate!
    if only i could hear it over the road/exhaust noise.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  2. #22
    Feb 2007
    Perth, WA
    Quote Originally Posted by static1800 View Post
    Would much rather spend 1k on a home stereo, but each to there own.
    What if i've done both? About to drop money on home threatre next
  3. #23
    Feb 2007
    Bunyip, Victoria
    I do car audio, couse if i turn on a radio at home my parents cut sick, let alone a $1000 home theater system.
  4. #24
    Feb 2007
    Perth, WA
    Mine are a bit like that, but my "noisy" room is at the far end of my house so tis okay
    And who said i was only going to do $1k on home theatre? HEHE
  5. #25
    Aug 2006
    Skye, Victoria
    Thats right, right now my home theatre outdoes my car stereo 5:1
  6. #26
    Feb 2007
    Perth, WA
    Werd to that!
  7. #27
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by BlackVr6ix View Post
    yes bt you only have 1 speaker pluged in a crapy tape deck.
  8. #28
    Aug 2006
    Skye, Victoria
    Try again hahaha
    right now i have a
    - sony cd deck
    - Polk MMC6500 splits
    - Polk DB650 Coax
    - Soundstream something or other 3 chan 2x60 & 1X250
    - 2 x Clarion PA10S
  9. #29
    Feb 2007
    Bunyip, Victoria
    System Update.
    My new sub should be arriving today, so i'll update everyone on wahts running and how in the VR6.
    Im now running a center channel in the dash, using a Clarion SRC1074 4" co-ax, running mono, bridged across channels 3+4 on my aplifier. These channels also run my top corners, a pair or SRC1074's. These speakers run freqs over 400hz to 22khz.
    The center channel has had the tweeter disconected, so as to concentrate on Vocal freqs, and will be getting an adjustible attenuator, at the center is a little too dominant at the moment.
    The Mid bass speakers are VDO MPS1700, as per the first post, These are running at full range on channels 1+2 on the amp, with a crossover to bandpass them to about 400hz.
    I need a second amplifier to run my rear speakers, and the center channel seperatly from the fronts, so that i can tune it a little bit better, the center also needs to be raised into the top of the dash.
    The sub is a DHD duel voice coil 15" off Ebay, nothing flash, cept for the dust cap, which flashes to the beat! A bit of a wank, but it was all i could find on there with duel 4ohm coils and a decent power handling.
    I will be running this as a 2ohm load to get the most out my aplifier, as like most monos, it does its best work at 2ohms.
    The sub should arrive today i the post, but ive been waiting for 2 weeks already.
    Try again hahaha
    Been flying under the radar hey
  10. #30
    Aug 2006
    Skye, Victoria
    Sure have
    you need to run a custom filter on that center channel that plays only stuff that goes to bot left and right otherwise it'll mess with your left/right split in anything recorded in stereo (basically everything these days).
    search about summed mono filters. it will help you in the long run i think.
