POLO with RCD510 Sub/Amp install
apolagies if this has already been covered,
but basically i have a cadence 12" sub with built in amp from my vr6, that i think would make a nice little bass upgrade for the polo.
it has high level inputs so i plan on using those, but what i dont know is due to the vw's CAN- bus system, where do i plug my acc power from?
i remember putting an aftermarket deck in my mk5 golf, and i ended up buying a canbus adaptor to tap power for it.
what id really like to do is splice a cable somewhere and run it to the back for the sub.
Also does running power require taking your wipers out to run through the firewall? or is there a grommet a bit lower/ somewhere else?
pics/ help would be greatly appreciated.
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
