![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
whats expensive here in Australia? tell me what you have looked at...
your location?
I have not been able to find any in australia. maybe just not looking in right places hahah. But majority I found seem to range from around 35-80euro. These more expensive ones also include steering wheel controls ect which are irrelevant in my situation, however i just though a drop of 40euro was quite sharp.
Im located in brisbane.
Is it possible to install without canbus, or in the long run is it easier and more functional just to add to the setup?
you can try chris at audio express in brisbane, there are others too, just depends on how much money you have to spend. people need to remember that it takes 2 things to do something right, time and money, if one of those is missing or short then the sums wont add up.
yes you can run without canbus, but you will have to turn your unit on and off manually, your call, for a small amount $145 a canbus adaptor is too cheap not to get to run the system as intended.
- You may not post replies
- You may not edit your posts
Forum Rules
