Use a spade bit, or a Uni-bit (Step drill). I think it's 26mm, but you'll need to measure the sensor to confirm.
You can use a holesaw and auger, but they're usually messy.
Hi all,
Quick one for those that have attempted to install OPS. The instructions (i just have the kaufatec ones for a jetta, but same size sensor in the polo) talk about drilling a 3mm hole from the inside then using a 'forstner' bit to drill out the hole for the sensor, but it neglects to say what size the forstner drill bit needs to be.
I don't have the kit handy to measure the sensor size, but has anyone done it and knows? Are they readily available?
My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
'07 Transporter 1.9 TDI
'01 Beetle 2.0
The best thing to do is measure the sensor.
I have some aftermarket ones fitted to my Hiace, and the guys used a hole saw. I asked them why they did not use a large drill and the answer came back that it was easier to control the bit on a holesaw than a large drill. The large drill tended to produce a more "ugly" hole.
