Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Please HELP with RCD510 with 9w7 retrofit for T5 Caravelle
    May 2015
    Hi guys,
    Really need your expertise here.
    I bought a MY2012 T5 Caravelle (7E)
    Bought;
    1) RCD510 (5KO 035 190)
    2) 9w7 (5K0 035 730 D)
    3) genuine harness and mic
    Installed it all in (wasn't too hard)
    The radio works well, even the OPS shows the rear sensors on the screen with no VAGCOM coding.
    however when i tried to change the long code for the CANBUS 19 to include 77 it wasn't there, in fact there were only 3 Bytes to choose from....
    Here is a fresh scan, please HELP a newbie!!!:
    Wednesday,20,May,2015,19:34:41:54149
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Ross-Tech: Home
    VIN: WV2ZZZ7HZCH049920 License Plate: VAO000
    Mileage: 85440km-53089mi Repair Order: 33333333
    Chassis Type: 7H (6N0)
    Scan: 01 02 03 08 09 10 15 17 19 25 56 69 77 0B
    VIN: WV2ZZZ7HZCH049920 Mileage: 85440km-53089miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    56-Radio -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CCHA) Labels: 03L-906-022-CAA.clb
    Part No SW: 03L 906 019 DH HW: 03L 907 309 K
    Component: R4 2,0L EDC H43 9133
    Revision: 26H43--- Serial number: 00000000000000
    Coding: 01254012231400080000
    Shop #: WSC 02756 790 50316
    ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
    ROD: EV_ECM20TDI01103L906019DG.rod
    VCID: 74E73EF5DF68AA817A7-8021
    2 Faults Found:
    5568 - Sensor for Ambient Air Temperature (G17)
    P0073 00 [032] - Signal too High
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4715 - No Communication with Instrument Cluster
    U0155 00 [032] - -
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
    Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
    Component: DSG DQ500-7F H05 1712
    Revision: 00H05V01
    Coding: 0014
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMDQ500021 001001
    ROD: EV_TCMDQ500021_VN75.rod
    VCID: 3F8DA1D9A6AE39D9575-806A
    No fault code found.
    Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
    Part No SW: 7E0 907 379 H HW: 7E0 907 379 E
    Component: ESP MK25A XT H43 0107
    Revision: 00H43001
    Coding: 208724AD09A8049E24AB9073AA5E10
    Shop #: WSC 02756 790 49152
    VCID: 377DC9F9869E01999F5-8062
    Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
    Part No SW: 7E5 907 047 BA HW: 7E5 907 047 BA
    Component: Climatic-T5 H19 0404
    Revision: 00001009
    Coding: 0000000402
    ASAM Dataset: EV_ClimaticT5 A01003
    ROD: EV_ClimaT5Basis.rod
    VCID: 6FED3199B64E8959875-803A
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 087 H HW: 7H0 937 087
    Component: BCM T5GP H+4 H47 0251
    Revision: BO047001 Serial number: 0429 269110622
    Coding: BAB879380E21201300200810242B8CD40000410F6004000030 0000000000
    Shop #: WSC 35683 123 104857
    VCID: 3979CFC1B08A17E9691-806C
    Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-801.CLB
    Component: J386__TSG_FT 002 3311
    Coding: 010000
    Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-802.CLB
    Component: J387__TSG_BT 002 3311
    Coding: 000000
    Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
    Part No SW: 7E0 919 475 D HW: 7E0 919 475
    Component: PARKHILFE 4K H11 0013
    Revision: -------- Serial number: 47301120800438
    Coding: 118101
    ASAM Dataset: EV_VW75XParkAssis4K A01006
    ROD: EV_VW75XParkAssis4K.rod
    VCID: 3365FDE99AE6EDB9A3D-8066
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
    Component: VW10Airbag00B H06 0013
    Revision: -------- Serial number: 003HL007WDMT
    Coding: 000000000000000000000000000000003042
    Shop #: WSC 02754 790 50316
    ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
    ROD: EV_AirbaVW10BPAVN750_SK12.rod
    VCID: 3561C3F19492F3898D9-8060
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 7E0 920 860 E HW: 7E0 920 860 E
    Component: KOMBI H04 0305
    Coding: 160A00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
    ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
    VCID: 2A5BE08D4D2CAC7110B-807F
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 7H0 937 087
    Component: GW-K-CAN TP20 H47 0251
    Revision: BO047001
    Coding: 042300
    VCID: 70EF32E5A37096A19EF-8025
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0305
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
    VCID: 6ADB208D8DAC6C71D0B-803F
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 HW: 5K0 035 190
    Component: Radio RCD510 040 0167
    Revision: 00000001 Serial number: VWZ1Z3K3531926
    Coding: 0800020001
    Shop #: WSC 10580 123 65156
    VCID: 62CB48AD7D9C343118B-8037
    Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H09 0100
    Revision: 3A001001 Serial number: 00000158754925
    Coding: 410D000100000000
    Shop #: WSC 02756 790 00000
    VCID: 306FF2E563F0D6A1DEF-8065
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007662471347
    Coding: 0A00000000010110
    Shop #: WSC 00015 115 12345
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA.rod
    VCID: 264314BD59348811343-8073
    End-------------------------(Elapsed Time: 02:22)--------------------------
    You need to go to the installation list on newer gateways, not just coding. It's easier to work with.
    May 2015
    Thanks for that, I certainly added 77 in the list, but it's not showing up in the canbus as a byte
    May 2015
    As you can see in the scan
    Sorry didn't read the whole scan on the phone.
    What is the actual question? You have telephone detected.
    May 2015
    Yeah, but in the Canbus there is no byte for 77
    Again, what is the question?
    You have a device at address 77. You can code it if you need to (in most cases no need to change any coding on the telephone modules)
    May 2015
    Ok, I'm sorry if I haven't explained properly my question.
    May 2015
    I was following the instructions I found here https://drive.google.com/folderview?...05zNXNpa0ZHbHM on the installation and coding. Please see the 9w3 file
    May 2015
    You will see the long code selections for 77 should be in byte 5 but in my control module I only have the first 3 bytes
