If you coded 77 with VCDS then it should show up But then again I think you said you didnt have steering wheel controls? If not then it wont show as you have no way to control the data in the display.
It is definitely, black and white but it didn't show when I coded it, maybe I did something wrong. What can I do now?
DARKHORSE DEVELOPMENTS
BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. 0420839266
BRISBANE/GOLDCOAST/IPSWICH
www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
Just to be sure I've done everything correctly. What bytes/bits in 77 must be enabled for this to work?
Just coding 77 to gateway installation list is all you need.
Ok, will look at it tomoz. Ps bought a mk6 steering wheel and mfsw module and going to try to install it this week when it arrives.
FWIW.....9W7 installed into a 6R Polo today.
No display in mfd, because mfd display is controlled from the right hand stalk. Steering wheel controls are basic volume, station selection, mute etc.
I'm thinking the same for your T5. MFD controlled by right hand stalk?
I bought 131420638775 on eBay. So are you saying the buttons on the right side won't control the mfd? So I would need the right stalk assembly?
sorry...didn't notice your comment re the MKVI wheel.
in short...not sure if that will be enough to get the mfd to kick in with more info. The techo's will know if that is enough, or if the mfd 'module/control will require some 'tweaking'.
My comment was based on the Polo wheel, which has volume controls etc on left hand side, but no controls on the right. MFD is controlled off the wiper stalk.
Just checked my wiper stalk and it has trip computer settings control for mfd on it, so theoretically it should work in any case. I will let you know
No need for right stalk as the t5 uses the same bus as a polo so all the programming is done at the bcm. After fitting the mk6 standard mfsw (not gti, so I didn't need a new airbag) I had to get a new airbag loom connection. The buttons still not working even after I completed the Lin connection and the 12v. I'm suspecting a faulty airbag loom ATM. Will keep you posted
