Results 1 to 8 of 8
Thread: Please help: Fiscon Pro/Basic Plus Installation
Threaded View
  1. #4
    Jul 2009
    Singapoe, Singapore
    Quote Originally Posted by Swallowtail View Post
    There is room yes, but it can be a bit of a pain in the butt. Once you have the adapter cable on the back of the stereo, we found that getting the stereo back into the space was a little tricky as the large cable and plugs needed to be fed down into the gap at the bottom rear of the head unit cavity a little bit. The cables and the unit won't fit in the space at the back of the head unit.
    Once the head unit is in though the cable that runs to the Fiscon unit is quite long. I had mine temporarily mounted on the firewall with sticky tape, but re-located it last night to under the center console in front of the gearstick where it squeezed into a nice cosy gap.
    thanks for the tip!!!!
    I fitted the fiscon after seeing the posts...
    THANKS Swallowtail!!! you are RIGHT! there was no way the harness can be squeezed "behind" the HU.. I had to squeeze into some other gaps below.
