Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Planning a nice audio upgrade for RNS510 in Octavia
    Apr 2009
    Northern Tasmania
    Polk Audio upgrade for RNS510 in Octavia
    2008 Skoda Octavia wagon with factory 8 speaker kit and an RNS510 I installed.
    Got a bit carried away and bought a few things (as you do). Planning a Dynamat sound deadening 10455 kit (should be able to do heaps with that lot (added later - not that much as it happens). Used 2 kits to do the whole car right from tailgate to firewall. Another 4 sheets to do the doors. Also will be doing Dynaliner.
    Bought:
    JL Audio CL441DSP CleanSweep (not strickly required, but apparently it cleans up the factory audio and then 'tunes' it for the car - summit like that). (decided not to get that. Instead getting the unit below*)
    'JL Audio CL441DSP CleanSweep OEM Audio Interface: The CleanSweep uses a 32-bit digital signal processor to remove the factory adjustments, then sends your external amplifiers a perfectly clean signal. The CleanSweep connects to your factory radio's speaker wires, then takes the output of your factory radio and eliminates the peaks and valleys of the preset equalization, leaving a pure, unadulterated signal for your aftermarket amplifiers, speakers, and subs to work with. Since the CleanSweep attaches to the speaker wire outputs of your factory radio, it doesn't interfere with any factory radio functions. Once you've connected it, pop the included CD into your stereo, and the CleanSweep corrects the equalization in as little as 20 seconds. You don't have to adjust anything - the CleanSweep utilizes its built-in 120-band digital equalizer automatically, without the need for external control devices. If you choose, you can still use the factory radio's volume, treble, and bass controls as well.'
    Polk Audio PA D4000.4 4 Channel Amplifier
    PA D4000.4 - Amps | Polk Audio®
    Planning a nice audio upgrade for RNS510 in Octavia-747192121938-jpg
    Polk Audio MM6501 front speakers
    MM6501 - Car | Polk Audio®
    Planning a nice audio upgrade for RNS510 in Octavia-747192114541-jpg
    Polk Audio MM5251 rear speakers
    MM5251 - Car | Polk Audio®
    Planning a nice audio upgrade for RNS510 in Octavia-747192114534-jpg
    No sub as I'm not into heap big wampum. I'm going for clarity and quality rather than volume.
    What I'd like is a section of wiring with an RNS510 type connector on each end so I can add the amp without having to cut the cars wires. Just wire the amp and JL doo dah into it and use the cars existing speaker wires (if they're beefy enough and don't have special connectors at the speaker end). If I buy one made for adding an MDI to the RNS510 like below, get rid of the MDI stuff:
    Wiring Harness VW Media IN MDI FOR RNS510 RCD510 RNS315 | eBay
    *decided not to get the JL Dudio Cleansweep. Instead getting a:
    Rockford Fosgate 3sixty.3 processor which seems to do what the Cleansweep does plus you can plug it into a computer and equalise the stereo to suit your setup/needs.
    3SIXTY Digital Processors - 3SIXTY.3 - Rockford Fosgate®
    Also decided kaanage below was right and I should get a sub. So got a:
    Polk Audio MM840 8"
    MM840 - Car Subwoofers | Polk Audio®
    Planning a nice audio upgrade for RNS510 in Octavia-747192114558_1-jpg
    Polk Audio PA 1000.1 amp (overkill for that sub, but it was going cheap(ish))
    PA D1000.1 - Amps | Polk Audio®
    Planning a nice audio upgrade for RNS510 in Octavia-747192121914-jpg
    Various wiring kits, Dynamat and things from here:
    Car Audio Accessories - Ryda
    Elite Electronics, Welcome to our Online Store
    Most of the Polk Audio stuff was refurb off the Polk ebay site. All of it looks new.
    Added photo's in a post on the next page.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
    You don't need a line level converter (which I assume is what the 'Cleansweep' is (unless you need to run a trigger from the LOC to the amp in order to turn it on...most amps these days can trigger from an output from just the speakers)
    You can set the RNS to line level balanced output by changing the settings via VCDS.
    You can certainly make up a wiring harness to add the amp in without splicing.
    You could buy something like this and cut it up to splice in the amp connectors as required.
    There is a basic guide here that outlines the steps somewhat...
    Enjoy the upgrade I haven't done dynamat because I'm lazy, but am relatively happy with my budget upgrade.
    Apr 2009
    Northern Tasmania
    It's not just a line level converter (anyway, I think the amp could do that), but corrects the factory radio output to give a nice clean flat input for the amp. Explained in the first ten minutes of this
    JL Audio CleanSweep® OEM Interface Product Tutorial - YouTube
    From their blurb:
    'Unlike primitive line-output converters that only reduce the level of factory audio signals, the CleanSweep® CL441dsp employs a powerful DSP (Digital Signal Processor) to automatically analyze the frequency response of a full-range factory audio signal and then applies 30 bands of powerful equalization to each channel. This counteracts any factory equalization and provides a clean, flat signal for your aftermarket amplifiers and speaker systems to sound their best.'
    So its a LOC converter with a DSP. At the end of the day its designed to turn a speaker level unbalanced output into a line level output (with some fancy processing thrown in) which is likely superfluous when the head unit is capable of outputting line level out.
    You'll have to do some testing and let us know your findings. Test with the RNS running speaker level outs through the Cleansweep, then with RNS outputting line level out through the Cleansweep, lastly without the cleansweep and RNS set to line level out.
    Jul 2010
    Quote Originally Posted by wfdTamar View Post
    hope this helps.....RNS 510 Pin Assignments
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Oct 2010
    Melbourne, VIC
    Done properly, a sub will add clarity and quality as well as extension and increased power handling. By properly, I mean the bass being filtered away from the 'normal' speakers and redirected to a sub that is set at the same output level as the main channels over the crossover range.
    Subs get a bad reputation because people set them up to run at excessive levels and without rolling off the main channels so there is a massive hump due the overlap.
    The Cleansweep looks like a pretty good idea if the factory head unit is heavily EQ'd but does anyone know if that's the case with the RNS-510? If the head unit's output is pretty flat, then it'd be a waste of money. It's too bad they haven't incorporate LPF and HPF filtering around 100Hz for a sub signal output (in fact, they've done the opposite with the summing CL-SSI module)
    Resident grumpy old fart
    Apr 2009
    Northern Tasmania
    I asked JL Audio if the factory equalisation would be on the line level output and they don't know - said to test it with an RTA (Real Time Analyser - like a graphic equaliser display). Free software for that available.
    Considering changing the Cleansweep for the Fosgate 3sixty3.3 - it seems to do what the Cleansweep does plus you can adjust the equalisation after - put your own 'factory equalisation' in by connecting it to a computer. $569 compared to $338.
    Apr 2009
    Northern Tasmania
    Cancelled the Cleansweep and getting the Fosgate - so now I can add a sub if I want. Considering one of these for the left rear boot 'pocket'. Probably won't have room under the seats as the amp and Fosgate will most likely go there.
    TS-WX210A Space-saving Amplified Sub (150W - 2010 Model) - Pioneer Car Speakers, Sub
    Planning a nice audio upgrade for RNS510 in Octavia-screen-shot-2014-03-15-12-13-56-pm-png
    Means I don't have to have something permanently in there if I want the space and since I don't want huge bass that would seem to be enough.
    Apr 2009
    Northern Tasmania
    Ok, now I'm getting a Polk Audio PA D1000.1 amp and MM840 sub (Polk refurbs, so not ridiculously expensive).
    Oct 2010
    Melbourne, VIC
    That's WAAAAAY more power (amp) and power handing (sub) than you need but if it's cheap then it won't hurt either
    The Fosgate DSP module looks awesome
