Results 1 to 10 of 16
Thread: Plan to replace RCD 310 by RNS 510 in 2011 Tiguan
    Aug 2011
    Westmead
    Hi,
    Before I order the RNS 510, I just want to make sure is it that simple I can replace it by myself. I found some people they need re-coding or VCDS, VAGcom, can-bus issue, etc.... on the other hand some people take only 15 -30 minutes to replace it.
    My Tig is originally equipped with MDI and bluetooth. Is there any hints for me to pay extra attention before I place the order? Or should I ask someone to fix it becos i know nothing about electronic / electrical?
    Explorer2
    2017 Tiguan 140 TDI Driver and Comfort package
    2016 AMG CLA 45 OrangeArt Edition
    2011 Tiguan 103 TDI; 2004 Subaru Forester Luxury Edition
    Jun 2009
    Quote Originally Posted by Explorer2 View Post
    Hi,
    There is a guide to replace the RCD310 with an RNS510.
    It is pretty simple except you will need a hex head screwdriver with a t20 bit to get the unit out (from memory)
    I never had MDI or blutooth so i can't help with that.
    Here is the guide: http://jamaicastore.com/images/RNS_5...tion_Guide.pdf
    Aug 2011
    Westmead
    Thanks! team_v!
    I am still struggling with the compatibility of existing bluetooth, MDI and AUX and MDF. I am still doing some research on it.
    Explorer2
    Jul 2010
    FWIW, my DIY installation was plug and play, with no need for VCDS re-coding.
    MDI, MFD and steering wheel buttons worked fine and unchanged!
    However ... whilst we have the same MY car, I upgraded from a RCD 510 and don't have bluetooth.
    MY11 Tiguan 147TSI (SOLD)
    Aug 2011
    Westmead
    Thanks aussietig!
    I will give it a try later!
    Explorer2
    Apr 2010
    If you don't have VCDS, you will likely find that the unit works fine, but you won't get the Navigation screen on your MFI/MFD (which shows compass and navigation instructions). When I installed mine, all the steering wheel buttons worked for changing volume/skipping, etc (wasn't expecting it to work based on what I had read).
    If you need to get a T20/T25 screwdriver, go for a magnetized one (or buy a magnetizer that'll add the feature to your current screwdriver) - last thing you want is to drop a screw inside the dash only to have it rattle when you drive).
    Also remember, when you first install the RNS510, the maps might go all haywire when you first drive - don't panic, this is normal and it should correct itself as you continue driving for 10-20 minutes.
    Aug 2011
    Westmead
    Thanks for advice! I tried to search the RNS 510 from ebay and they are usually 2nd hand or used or disassembled from other cars. Should I buy a brand new or the new ver. F from Poland (only equipped with European map at the moment). Any suggestion to which seller?
    Explorer2
    Apr 2010
    Did a quick search on Ebay - best I could find (price + map version) is here:
    Volkswagen Navigation System RNS 510 V4 MAPS vw rns510 | eBay
    Don't worry if a unit doesn't have Video in Motion (VIM) enabled, you can do it yourself for free by burning a CD that updates the software.
    Aug 2011
    Westmead
    Thanks! Buddy Ryan! I have asked the seller whether it is LED version. If so, I will probably order it! Thanks again!
    Explorer2
    Jan 2008
    Lower North Shore
    Hey mate. Would you mind letting me know if it is LED please. If so i'll wait for the next one and grab one as well.
    LS
    In Carport. R
