No drama, I'll call the EA guys and see if they can point me in the right direction.
Let me know if your install stays right over the next week or so.
MG
im the last person to ask wrt the technical stuff. they had me at "hello" before things went "bzzzzzzzzzz" and i turned my attention to how green the grass was.
u can always give derek at EA a call, or email him and he might point u in the right direction in terms of a shop in melb
2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
MG
MKVi GTI | Candy White | 5dr | DSG | 18" Detroits | Bluetooth | MDI | RVC | Tint |
Feel like a kid in a candy shop every drive!
Walbjj
Can u tell how much he charge from u
Derek wanted to have another look at my car and see if he can get it working so it's booked in for next Friday, I will let you know how I go.
| .:R32 | MY08 | Deep Blue Pearl | Sunroof | RNS510 | MDI | OPS |
Markwid,
How easy was this install (I know that an "it's all relative" question) in terms or running the wires through the car, drilling into the rear bumper, connecting into the can gateway etc. I'm fairly handy, have a steady hand etc, but I'm no auto electrician that's for sure.
Basically, I'm trying to gauge how complex the install of rear ops into a mk6 gti is before I part with the folding.
Cheers,
MG
Not easy for sure. Not something to DIY for a layperson. I got mine installed for me at vwvillage.
You have to know :
- how to remove rear bumper
- drill the holes
- run wiring from rear right to front right
- remove knee airbag to get to controller
- wire correctly and draw ignition switched power correctly
- VCDS coding
If you feel comfortable doing all the above, go for it.
2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
yep, derek said he spent well over 10 hours on it with all the info from the internet on 3 different occassions. and only after getting info from a vw electronics advisor that carsystems.pl gave me the mobile number to, did he actually get it working.
derek said that although the wires are labelled and colouredn in a certain way, they actually dont correspond to the "correct" connections.
its doable, but how much is ur time worth?
Thanks gents, great info.
Volkewerke in Melbourne can do the install for me which is good. I am about to hit the buy button from carsystems.pl / eBay but the kufatec wiring work looks much better in the pics, for the sake of a few extra bucks would I get a better outcome (in your opinion) with the kufatec wiring harness and the car systems sensors, control module, switch etc. Or am I paying a few extra bucks for neater looms which I could wrap / cable tie myself anyway or will it make absolutely no difference.
Looking forward to hitting the go button on this one!!!
MG
Whatever you do, buy as one complete kit. There are so many module and sensor part numbers that you need to have the seller provide some sort of guarantee of compatibility. The wiring, from what I have read is fairly standard and the loom configurations are easily available online. It's only the coding that is a little elusive.
