Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: OPS RNS-510 Installation Problems
    Jan 2011
    Question OPS RNS-510 Installation Problems
    Hi,
    I Recently purchased this 4 Sensor OPS Retrofit kit from ebay:
    VW OPS optical parking system RNS RCD 510 MFD3 GOLF PDC | eBay
    I had my sensors colour coded and my spray painter, and today I took my car to European Autotech to have the system installed onto my MY08 R32.
    The guys there told me that they had tried to install a kit earlier in the week and had problems, so they would do a test install first to make sure all of the coding was right, and the system was behaving itself.
    I went back to pick my car up this afternoon and it turns out that my system is having the same problems as the previous install they attempted.
    The unit appears to communicate correctly with the CanBus Gateway, and beeps as expected, however there is no display on the RNS-510. Derek said they tried every combination of configuration they knew, but they were still unable to get it to work properly. He suggested I contact the seller and request a comprehensive wiring diagram, which I have done, but I'm not expecting too much of a response from them.
    I was hoping that there would be someone on here who has successfully installed this before and might be able to help me get this to work. Derek is happy to attempt another install on the system, and I am happy to go back to him to get it installed, but I need to find out how to get this to work properly in the car.
    The parts supplied with the kit are:
    -PDC control unit (part no. 1Z0 919 475 B),
    -4 parking sensors for rear bumper (part no. 3C0 919 275 S),
    -4 holders for parking sensors (for fitting into bumper, part no. 1Z5 919 491 C),
    -Wiring for sensors (conects parking sensors to PDC control unit),
    -CAN BUS wiring (goes from front of car to the rear where PDC Control Unit is located).
    The PDC Control unit part number is a sticker on the front of the unit, im not sure whether the part number under the sticker is the same.
    If anyone could shed some light on a wiring diagram, or what the problem might be with configuring the unit, it would be greatly appreciated.
    Thanks,
    Mat
    | .:R32 | MY08 | Deep Blue Pearl | Sunroof | RNS510 | MDI | OPS |
    Jul 2011
    Its possible that your wiring needs to be checked, i've checked out the kit you purchased and i noticed these minimum
    requirements are required to operate it correctly
    (The CAN BUS gateway needs to be version E or later. The head unit VW RNS 510 has to have a software index of at least 1000. Unit
    VW RCD 510 has to have part number 3C8 035 195. VAG COM system recoding is required after fitting in order to make it work)
    have you checked all this??? Could post a copy of gateway installation list??
    Sep 2009
    seaforth, nsw
    hey matchew, that would be i that was trying to install the ops into my mk6 gti.
    markwid, a forum member here actually got it to work in his mk6. george at vw village got it running, not sure what he did. he has offered to look at it if it gets stuck
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
    Jan 2011
    grtuned,
    I think you're right, it's a wiring issue, not a hardware issue. My CanBus Gateway is a Revision K and the RNS-510 is a version C LED that was only manufactured in October last year and Installed in January this year so it should meet all the minimum requirements.
    When European Autotech did the install it was only a temporary fit to check that it worked, I don't have a VCDS cable so unfortunately I can't get a scan to post.
    Quote Originally Posted by walbjj View Post
    Walbjj, you have a PM.
    Markwid, if you have any suggestions I would really appreciate your input.
    Feb 2010
    Hello guys. Just spotted this thread.
    Sorry but I have bad news for my OPS retrofit.
    George at VWvillage got it to work - of course I have no clue as to what he did to get it to work. Here comes the but. After a week, intermittently it will not work. At the same time, in the morning, I will get a audible warning "ding, ding" when I open the car door.
    I have disconnected the PDC unit for now. When I have some free time, I will bring it to George to have a look.
    Doing a bit of google, I found this possible issue and solution.
    2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
    Jan 2011
    That's no good markwid. Hopefully you can get it working.
    I would be interested to hear how you get on with it.
    I have come across that information myself in my searches. I'm hoping that is the cause of the problem and that it's an easy fix. All of the part numbers I have seem to match up with the ones specified by Maverick on his website so I don't believe ther should be an issue. I'm hoping it's an easy fix and it's just the wiring.
    Feb 2010
    Well, it is confirmed that my OPS was wired to constant power - this could be the problem. The suggested solution is to wire to ignition switched.
    Will do this sometime in the week and report back how it goes.
    Sep 2009
    seaforth, nsw
    hey mark, how long did george take to work on it. im giving it another go but if its no good, i need to find time to get out to vw village and see what he can do
    Feb 2010
    I am guessing that your install is partially done already, so best talk to George and get an estimate.
    Jan 2011
    It will be interesting to see whether there is a difference in operation once you get it wired to ignition switched power.
    I'm still in the same boat as walbjj. Mine isn't working, or parially installed and I'm considering getting a refund and getting Derek to supply and fit a system for me.
