Neater wiring shouldn't make a diff. The eBay one should suffice
Printable View
I have reverse sensors already installed in my Golf v but since i installed the RNS 510 i would also like the OPS can you buy only the control unit[PDC Control Unit – 3C8 919 475 (3C8919475) for the change over and is it not too difficult thanks
Are ur sensors oem or aftermarket? Where is it wired to? What wiring loom does it use?
These r the type of things that need to be known as u can't plug the control unit into any sensor and it needs to be wired correctly.
As far as the control unit, email the carsystems vendor and ask for only that but I would tend to just buy they complete kit and get Derek to install as I have neither the time nor knowledge
Hey matchew how did u go with ur ops?
hey ian, if they are the original reverse sensors, then in theory they should work. the question is, what are they attached to currently? a rcd310?
that would jsut be a audio output. i would assume a new control module and coding would make it work on the rcd/rns 510
I think OPS is also possible on RCD310.
http://img.skitch.com/20110812-r4hq3...dmymnysmdg.jpg
I saw this one on Ebay from the UK [control unit only] and asked about the unit , they sent me back a email stating i could have the control unit by its self delivered for $150 does this sound like a good price ?
eBay Australia: Buy new & used fashion, electronics & home d
I doubt many have had experience with doing it this way. Only one way to find out. Care to take a $150 gamble?
Hi guys,
One last question. Does the car systems kit have the right size switch. On eBay it looks like a half size switch. Also does the switch install near the shift boot / traction control button?
Any chance of a photo?
Cheers,
MG
