Hi Guys. I'm after some help. I'm looking at updating the firmware and maps in my Octavia RS. I've downloaded the updates from the link in this thread, but I can't access the hidden menu to check that it will work and not screw up my car. It's an MY11 build. Is it going to be relatively safe or am I paying with fire not knowing?
Thanks for your help.
Steve
As long as you have the map disk you can go ahead. There is no additional risk not knowing the current firmware.
Sent from my HTC One X using Tapatalk 2
A and B units have supposed limits as to how far the firmware can be upgraded. They'll be the oldest units from 2009 & early 2010. You can always pull the unit out of the dash to check the version on the sticker if you want, or connect VCDS to it to check.
Thanks guys. Anyone got a tip on what type of disc to use and a program to burn it on Mac? Had a look and the slowest the native burning program burns is x4
Sorry, did someone say DAB?
5128 has some DAB software, my RNS510 has "DAB hardware" shown as present but no software. (4120 currently).
Does "DAB hardware" mean DAB only or DAB/DAB+
Is it possible DAB+ might spring into life with 5128 or shortly thereafter?
