Page 18 of 24 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #171
    Original post updated, as has the main Aus firmware update guide with new version as well as new links to the brand new rnsfirmware.com domain thanks to The Hawk!
    European update to come.
  2. #172
    Quote Originally Posted by foogy69 View Post
    Hi kamold
    Is there any chance of knocking up a version of the disc for us Europeans with a 75/20/5 partition.
    I could have a bash myself, if you could update the dead links to the files required that are mentioned in this thread
    How to re-partition the HDD in your RNS510
    I don't have the West Euro maps and dont intend to download them, but my feeling is that the maps partition will need at least 25% of available space on 30GB hard drives for v9 maps so have made a version of 412x firmware with 70/25/5 ratios.
    You can download it here
  3. #173
    May 2011
    Greece
    Is this version compatible with B units?
    Need VCDS?
    VIM and secret menu enable?
  4. #174
    Re: New firmware for RNS510/Columbus versions 4120 and 5210
    I would NOT install on a B unit. It may work but not worth the risk of finding out it doesn't.
    Sent from my HTC One X using Tapatalk 2
  5. #175
    So many thanks for the hard work...updated smoothly. Everything stayed intact. Wooo!
    MK6 CS GTI
  6. #176
    Thank you for this updated firmware.
    Unfortunately when the upgrade gets to the HDD, an 'error 135' comes up. I then get the SWL update failed screen with the message 'error HDD error partitioning HDD' and a software loading error 010303.
    I have tried different discs, CD and DVD and all have the same result.
    The unit is a 1T0035680F
  7. #177
    Not sure what the issue is, have checked the script file all looks good. Let me look into it and get back to you.
    I presume your HDD is 40GB?
  8. #178
    OK found the issue with EU 4120 custom...I can't add three numbers correctly to 100....omg...
    OK correct image is being uploaded. Will be available in about 2 hours. Apologies.
  9. #179
    Apr 2010
    haha you're on a hatrick now. I won't be the first to test your next release
  10. #180
    Everyone knows men can't multitask...dont move house and create custom firmware images guys!
