Page 1 of 24 12311 ... LastLast
Results 1 to 10 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
    There are some new factory firmware revisions floating around the net.
    Update: I would advise AGAINST loading version 512x these until we know more about it.
    At a minimum, DO NOT attempt to load these without VCDS on hand as your RNS coding will be reset to default, so BT, OPS, RVC etc will likely not work properly until recoded.
    Now available
    Version 412x has been tested and adds RDS and a male english nav voice as main new features. The original firmware image has been modified to conserve coding (no VCDS required) as well as 90/5/5 partition ratios for Australian maps, plus VIM and secret menu!
    The main Australia firmware thread has been updated with links here
    Jul 2010
    Hear, hear buddy!
    But would much rather hear the news of a revised map floating around!
    Nevertheless, a really good safety sign to look out for is when units on eBay have upgraded to the new version.
    Or just wait for kamold to develop fool proof link & guide!
    MY11 Tiguan 147TSI (SOLD)
    Apr 2010
    I thought you two were the trailblazers
    If I brick mine I'll put my hand out for donations to buy a new mainboard, how does that sound?
    Apr 2009
    Looking at buying a 'H' version from overseas at the moment and it has firmware 4120.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
    Apr 2010
    Adelaide, South Australia
    Quote Originally Posted by Ozram View Post
    where from ozram?
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
    Jul 2010
    Ok ... have successfully loaded FW 4120 on my H unit.
    Can confirm the following:
    • Has VIM & secret menu enabled already
    • Normal partition of HDD
    • Will lose custom POI & favourite destinations. So need to reload both via SD card.
    • I have no music on HDD, but most likely will lose music as well
    • Lose your custom settings on the unit. So just need to go through every button/menu and reconfigure (e.g. language, time & radio stations)
    • Lose your custom coding in Module 37: Navigation. So need to remember your long coding beforehand and paste back in via VCDS
    • Telephone & RVC remained intact. No VCDS recoding required
    • Map remains intact, but unit starts up in German and think it's in Germany. Just needs to lock onto GPS satellites to warp back.
    Only noticeable differences thus far:
    Improved seat details
    Radio text display available under 'Extras' button
    So not really exciting and somewhat expected based on the revision number.
    Subsequent successful install of FW 5218 on my H Unit.
    • Same radio text display option under FW 4120 is available.
    So again, not much difference from the new baseline set above on FW 4120, other than the following:
    • H unit appears to be a P unit after install
    • Appeared to have installed some DAB related software. But probably not functional as necessary hardware not there
    • Install only took about 20-25 mins only upgrading from FW 4120, whilst on screen message did say 56 mins.
    Jul 2010
    based on all those "losses" and the "no gains" - i'll pass.
    that balance fader is not new - unless there is some tiny detail i missed.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Jul 2010
    Quote Originally Posted by dArK5HaD0w View Post
    There is also radio text now.
    Updated pics above.
    Anyone's prayer answered with this feature?
    Apr 2010
    AWESOME!!!
    Of course it would look better having the RDS text where it's showing the clock instead of hiding the 6 preset buttons. Also gotta admit I'm not a fan of that colour scheme you're running there
