(Told ya you were a trailblazer)![]()
MY11 Tiguan 147TSI (SOLD)
I had to downgrade my H61 unit from 5218 -> 4020 due to the electronic hiss and pop if the RNS510 is booting up while turning on the engine. Interestingly it did keep the radio text function, so win win I suppose.
That's interesting. Sounds like the 4020 downgrade did not downgrade the radio sw.
Sent from my HTC One X using Tapatalk 2
Attempted to install 4120 with kamold's 90-5-5 script but got a SWL media error (that said it also said for 1T1350...D (whereas mine is a C). Attempting to restart the unit just goes back into the upgrade process. So stuck in a loop where I have a black screen saying searching for SWL update.
Burning this ISO again to Imation CD-RW this time (tried Verbatim DVD-R before) and hopefully will have better luck. My biggest concern atm is whether or not the unit will turn off before flattening the battery, since I can't manually turn it off (could resort to removing fuse if needed). If this doesn't work I might try a stock 4120 (50-25-25) otherwise hopefully it'll let me reinstall the 4020 disk that I still have. Not that anything I've seen on screen would indicate it's wiped anything, just the bootloader appears to have changed.
http://i63.photobucket.com/albums/h1...114_181333.jpg
It hasn't done anything. Just force reboot it with setup eject Mic buttons with no disk in and it will reboot fully
Began with this:
And currently stuck here after trying a few different sets of media:
Will try that small recovery ISO and see if that helps at all. Any suggestions appreciated![]()
Just reboot as it says down the bottom.
Then you need to reset the counter in secret menu
Didn't reboot, plus was running out of battery, so used the recovery CD, then as I started driving home from work I reloaded 4020 (surprised it let me install with the key in), and lost coding and Setup options on the device. Got home and am now loading the normal 4120 disc instead of the modified one. Should go ok then hopefully a premodified 5128 iso will appear soon.![]()
4120 update started ok but checked on it just now and it's failed again, unable to boot.
Reloading 4020![]()
