Page 19 of 24 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #181
    Nov 2012
    Germany
    Hey Guys,
    Is it possible to modify 4120 for Index A RNS510?
    If someone is here, maybe he could create or upload this firmware.
    My Problem is, that I have "Regensburgsyndrom" and maybe 4120 could help
    4020a is unfortunately down.
  2. #182
    Mindarie, Perth (WA)
    you want 4020A? There is no noteable difference (performance and/or aesthetics) to 38XX.
    I have run both on my A unit...and can vouch that you gain NOTHING by choosing 4020 over 38XX.
  3. #183
    Re: New firmware for RNS510/Columbus versions 4120 and 5210
    Quote Originally Posted by shanny View Post
    Hey Guys,
    Please check your radio hw version. Do NOT install 4120 if you have 003 or earlier. This may damage your unit.
    Sent from my HTC One X using Tapatalk 2
  4. #184
    Nov 2012
    Germany
    thanks for your Experiences.
    Most important problem is my Regensburgsyndrom. But RadioText is here in germany insteresting, too.
    So: My hope is to get 4120 for A RNS.
    (Currently I found 4020a_70-25-5)
    @kamold
    Yes, i Know! I do not have SetConfig, so I could not create my own Version (Without Radio update)
    I have Rev. 0003
  5. #185
    OK found the issue with EU 4120 custom...I can't add three numbers correctly to 100....omg...
    OK correct image is being uploaded. Will be available in about 2 hours. Apologies.
    Your adding up worked great this time
    Thank you for your work, I now have lots more room for music
  6. #186
    @kamold
    I have Rev. 0003
    Yes you can use 4020a.
  7. #187
    May 2009
    Hello
    I've recently replaced my RCD310 with the RNS510 and am keen to get the most out of it. I was all set to update to 4120 when I read the comment about losing maps if your partitions are not already at 90:5:5
    Is my vanilla 4020 version likely to have that partitioning? The details of the unit are:
    HW-Version H64
    SW-Version 4020
    Map version HDD 7679
    Delivery part number 1T0035680H
    If my partitions are different, is it possible to backup my maps or download a current version somewhere? I don't have a cable.
    Many thanks
  8. #188
    Jul 2010
    Worse case, just re-install your map (CD_7679).
    You can find a link to it on this forum, if you click on the google search tab at the top of page and do a search.
    MY11 Tiguan 147TSI (SOLD)
  9. #189
    Apr 2010
    Maps are available to download so don't panic. Most likely your unit is not 90.5.5
    http://tinyurl.com/vwstuff
  10. #190
    May 2009
    Thanks for that. I have 2 ISO DVD +R, one for FW upgrade & the other to reinstate the maps I'll prob lose.
    The old links to maps didn't work, thanks for the alternate Ryan_R.
    I'll do the upgrade tomorrow night.
    Many thanks
