Page 17 of 24 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #161
    Jan 2012
    there are no maps in the firmware update. and if you download the version from this thread, you will lose everything stored on the hard drive - unless you had a kamold custom map installed before - there is (was) a V5 map floating around that is fairly up to date.
  2. #162
    Apr 2010
    Maps are a separate CD - can find them in a stickied thread in this section.
    Bluetooth can be retrofitted, many threads about it here. Check carsystems.eu or ebay for purchasing. DIY is fairly easy if you can wire up your home A/V system.
  3. #163
    Jul 2010
    Quote Originally Posted by zei20t View Post
    i was under the impression you don't loose anything if you upgrade from 402x, as it already has the 90/5/5 partition?
    i do have the v5 maps disc, incase i have to reload.
    i can always reload my music.
    but vcds settings (for bluetooth), rns language, vim etc etc - i don't want that lost.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #164
    Quote Originally Posted by dArK5HaD0w View Post
    Correct: if you already have the 90/5/5 partition scheme you won't lose anything.
    If you had previous 2 partition setup from 2760 etc, or standard 3xxx series with 50/25/25 then music and maps would be lost also.
    Coding is maintained with this version.
  5. #165
    Jul 2010
    so 30 mins later, i've now got the new firmware running.
    was a smooth install.
    didn't loose any settings on the rns510.
    i'm yet to check bluetooth & vim.
    i've lost the custom boot screen, but that was expected.
    will reload this soon.
    based on 5 mins of playing around - radio text is a hit or miss, depending on the station.
    haven't seen any weather information yet.
    thanks kamold for making the iso available. as usual, u made it a simple & painless experience. 1st with the 402x series, and now the 412x series.
    i gotta buy u drink or something next time i'm in sydney!!
  6. #166
    Jun 2011
    N/A
    Can you just confirm your partition sizes?
    HDD is showing approx. 33GB, so it has repartitioned it to 90/5/5. Thought it might have as it took a while to do the HDD step during the upgrade.
    And thank you
  7. #167
    Hi kamold
    Is there any chance of knocking up a version of the disc for us Europeans with a 75/20/5 partition.
    I could have a bash myself, if you could update the dead links to the files required that are mentioned in this thread
    How to re-partition the HDD in your RNS510
    I'll get an image made up for you Northern Hemisphere types soon, and will update the main guides with links. Dont want to make any time committments as I'm busy with getting ready to move but I'll see what I can do.
  9. #169
    Apr 2009
    Northern Tasmania
    I think this makes the unit shut down completely earlier than before (used to be 30 mins I think to stay on during a 'quick duck into the shops'). I'm seeing the VW logo more often.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  10. #170
    Aus
    It's my turn and did the upgrade to 4120 from kamold's custom Fw4020.
    As far I can tell, nothing was lost. Instantly I get the station text. My settings seemed intact. Haven't tested VIM etc.
    Again kamold, 3 cheers for you!
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
