Page 16 of 24 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #151
    Aug 2011
    I still get a loud oscillation sound and pop when I cold boot the unit with the engine on my H unit, going back to 4020 stops it though.
  2. #152
    Quote Originally Posted by readerr0r View Post
    Interesting. No idea what it could be. Can you detail all audio accessories you have ie BT unit including model/rev anything aftermarket, MDI etc etc.
    Given that the firmware rev affects it should be something you can avoid with a setting somewhere...
  3. #153
    Quote Originally Posted by l3lazin View Post
    kamold your a legend mate. I have a C unit which had been upgraded to 90/5/5 from your previous firmware that you did.
    All went to plan, no issues at all. I now have Radio text.
    Once again, thanks alot for putting your time and effort into creating these firmware builds for us! Also thanks to all the guys above for maning up and having a go before me.
    No probs.
    Will look to revising the main firmware guide shortly with this version once I get confirmation of partitioning working properly.
  4. #154
    Aug 2011
    I've got factory MDI and BT in my Polo and then it's running through to an amp in the boot, I've got the VW Soundsystem option selected so it provides low-level RCA sound to the amp. I'm then using the CD Changer remote line as a remote for the amp.
    I'm not sure if it's a bug with the Sound System option or if the CD Changer remote line if turning on earlier than usual, but it all goes back to normal with 4020...
    At the moment it's a non-issue since going to 4020 keeps the radiotext, I just hope it gets cleared up in newer frimwares
  5. #155
    Re: New firmware for RNS510/Columbus versions 4120 and 5210
    Ok so its triggering the amp that's the issue. Possibly they changed the order that modules are started in the rns to boot faster or something...
    Sent from my HTC One X using Tapatalk 2
  6. #156
    Jul 2010
    remind me again - do i need to reboot after i put the dvd in, or do i simply follow the prompts?
    i plan on taking the plunge tonight.
    i'm currently on 402x.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  7. #157
    Jan 2012
    I did, came up with an error after inserting the disc while unit was on. so I turned the unit off and on again, worked fine after that.
    also remember to perform the upgrade WITHOUT the keys in the ignition.
  8. #158
    Apr 2010
    Yes, many forget that last bit. That said I once did a firmware installation while driving home from work (had run out of battery after numerous failed attempts)
  9. #159
    Jan 2012
    not a bad idea doing it on the way home and reloading the map data!
  10. #160
    Nov 2012
    Brisbane, Queensland
    Does this FW upgrade also include new maps? Can anyone from Brisbane comment on how up to date they are? Also, to save me starting a new thread, I just bought a GTI with RNS510, I thought it had bluetooth as it had a phone button on it but now I'm thinking it doesn't Is there a way to retrofit bluetooth?
