Page 15 of 24 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 236
Thread: New firmware for RNS510/Columbus versions 4120 and 5210
  1. #141
    Aug 2011
    vic
    Actually I just checked through the script files and VIM has not been enabled.
    Edit:
    New image is now available. Same location. Now with added VIM-ness.
    Sorry for being ignorant, but which post are you actually updating with these changes, I have scrolled back trying to find your links, but only came across a dead link.
    Thanks
  2. #142
    Re: New firmware for RNS510/Columbus versions 4120 and 5210
    Post #112
    Sent from my HTC One X using Tapatalk 2
  3. #143
    Jan 2012
    OK did the upgrade, went straight forward.
    lost connectivity to MDF (took a risk and did it anyway) but steering wheel controls and bluetooth works fine
    had to setup the radio presets control, but that was about it. maps etc seem faster!
  4. #144
    Jan 2012
    ok after driving to work this morning, all was fine. I must not have left the RNS long enough to talk to the MDF.
    no VCDS programming required. awesome work kamold!!
  5. #145
    Excellent. Was a bit confused about the MFD...its either all or nothing with the coding generally.
  6. #146
    Jul 2010
    so confirm - this new iso:-
    1.will keep the 90/5/5 parition (as i currently have with 4024),
    2.maps won't b lost,
    3.vcds settings (bluetooth & vim) won't b lost
    4.music won't b lost.
    if that's the case, then i wouldn't mind trying this out on unit. hopefully its compatabile with mine (3T0 035 680 A).
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  7. #147
    Jan 2012
    I can confirm that except for 4 (I don't have music on my HDD) that no functionality is lost with this upgrade.
    my maps were there, all my settings were there. partitions didn't change etc. you should be good to go!
  8. #148
    Jun 2011
    N/A
    another success story, my version F unit had 3970 from the factory so 50/25/25 partition structure, tried the image off gpsunderground to skip repartitioning but failed 3 times on various media, almost died at the thought of having to buy a new radio as the unit became unresponsive and remained at a black screen for 10 minutes, several times
    downloaded kamolds version and worked straight away, obviously wiped everything as it had to repartition/previous install attempts had wiped it, had to recode to get MFD functionality, but bluetooth continued to work both on the RNS display and the MFD
    now all working great, kinda missed radio text from my old RCD-310 so its nice to have it back, took 15 minutes to find satellites this morning though, we'll see how it goes tomorrow
  9. #149
    Quote Originally Posted by jameshero View Post
    Can you just confirm your partition sizes?
  10. #150
    Jan 2010
    City, NSW
    kamold your a legend mate. I have a C unit which had been upgraded to 90/5/5 from your previous firmware that you did.
    All went to plan, no issues at all. I now have Radio text.
    Once again, thanks alot for putting your time and effort into creating these firmware builds for us! Also thanks to all the guys above for maning up and having a go before me.
