Results 1 to 10 of 13
Thread: New To This??
    New To This??
    Just bought a T5 Multi 2006, it hasnt ever had a radio fitted but on my phone it showed a blue tooth listing?
    Unless I was just near someone else??
    Is the van set up for it?
    If so what radio should I fit I dont want to fit a sat nav one but one I can plug my iphone into??
    This is what I have behind the panels
    This might be better
    Jul 2011
    Old style connectors and din style fittings. No blue tooth option unless there is a touch screen type. Your options for radio are genuine mfd nav unit I also know of the square type rcd type radios that will fit. Only option for genuine blue tooth is touch screen unit. Search e bay.
    I have noticed to square covered sections in the overhead consol, would that be the mics for the phone?
    What model vw radio or sat nav will fit straight in
    What model number came in 2006 models?
    Thanks
    Jul 2011
    Quote Originally Posted by Scouser View Post
    Yeah should be ok but the wiring harness is for the later mk5 units. you should ask retailer if adapters for your vehicle are available
    I cant seem to find the aerial connector behind the das anywher?
    All I have is this
    Jul 2011
    thats an aerial booster you should find the remaining original aerial lead down there somewhere!!
    Ive just spent 20 mins trying to find the aerial with no luck
    Does anyone know which side or where it runs?
    I have noticed what looks like the antenna in the drivers side rear window?
    Thanks for the help
