Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Need help in amp installation.
  1. #21
    Nice work - that amp looks exy!
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
  3. #23
    Thanks neil.
    2 More questions
    A. went for a good test drive yesterday, notices the speakers at low volume has a whining noise, the power cable is already running isolated on left trim, only time then the wires are touching is at the coner of the seat going up the Amp.
    B. Any one know how I can take out the vent, the speaker is touching on the a/c Buzzing the piping, . I may need to drill a hole/ indent the pipe.
  4. #24
    Feb 2007
    The buzzing noise comes for the alternator. You will need a signal filter to filter out that static. Should have come with your head unit. There about 30$ from strafield if i remember corectly.
    MK1 GLS 3door
    A4 B7 2.0T
  5. #25
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by Soundofav6 View Post
    You may need to indent it. To do it on mine, I just closed the vent (with vent out of the car) and hit it with the heat gun till it was soft, then i carefully pressed in indentation into the tube and let it cool. The vent should still open and close if you have done ok.
    Nice install, but i dont remember having to run my speaker wire through the doors, probly couse i cheated!
  6. #26
    Quote Originally Posted by Spyda View Post
    A signal filter hey.. So which part of the car would that go onto ?
    Quote Originally Posted by ScienceVR6 View Post
    The thing is how do I take the vent out ?? I see the screw inside, is there only one screw ?
