i dont want to generalise but, i have found that most autobarn stores in adelaide are pretty poor installers, and have limited knowledge of anything other than the entry level equipment that they stock
yes they get the gear in ok, but quality and attention to detail isnt the best. would also stay away from sthrathfield and JB Hi Fi...
the golf/boras are relitivley easy to do a HU swap in, so i would suggest that you give it a crack yourself. if you have any questions post up here and theres plenty of people who can help out
in terms of speaker replacement i would upgrade your HU first like some others have suggested, you will be suprised how much of a difference it makes.
if youre dead set on replacing the speakers you will have to remove the door trims, drill out 4 rivets per speaker, make up some MDF spacers and then paint them, then put everything back together. you would obviously be running an amp, so would also recommend upgrading the speaker wire to a thicker gauge
theres also a few tutes on vw vortex which may help out
cheers, dan
