Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Nearly completed Boot install
    Feb 2007
    Bunyip, Victoria
    well, the showy stuff is coming for the open boot, i have re-aranged things abit, and generally improved on things, so i'll have to take more pics!
    Feb 2008
    Auckland NZ
    nice install man.
    have you tried facing the sub rearwards?
    it usually can expect arounjd a 3db increase in sub bass frequencies.
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by glidn View Post
    nice install man.
    have you tried facing the usb rearwards?
    Iv'e faced subs in every known dierection. I'm realy dont care for db cars, i just want it to sound right. As for sub bass gains, i prefer porting. It alows me to do things with the install.
    Feb 2008
    Auckland NZ
    Quote Originally Posted by ScienceVR6 View Post
    yeah i know what you mean,
    i have tried single 12 sealed.
    single 8" sealed
    dual 8" sealed
    Dual 8" ported, i found system blending the best by facing the sub rearward in my mk3.
    But not so in my MK4 golf, it sound way better firing the dual ported 8" upwards of all places.
    But as you know all cars frequency peaks are different. And it's the beauty of the EQ anyway.
    I i'm not into SPL at all only SQ.
    Feb 2007
    Bunyip, Victoria
    single 8" sealed
    dual 8" sealed
    Jeeze, iv'e used bandpass 8", Sealed 10", ported 10", dual 12" sealed, dual 12" ported, single 15" sealed, single 15" inverted, single 15" ported, dual 15" sealed.
    With most of the larger subs, i have noticed almost no differance when pointed in differant directions. The 10" always sounded best when pointed into the rear left corner!
    Feb 2008
    Auckland NZ
    well clearly you have use a few more configurations than i had.
    i have never actually played with a 15" at all always found them way to boomy, but then again if i had a EQ a hell of alot sooner maybe a would have,
    i guess personally i need as much boot space as possible. hence 12" was my limit, but now in the MK4 i think i may go to a 10" but most likely run a single 8".
    But i did play with a RE re12 in my mk4 but man that was seriously insane. More than enough SQ and SPL capabilities. Either way.
    Well good to hear your system is going well.
