Results 1 to 10 of 12
Thread: Sub box help please :)
    Jul 2007
    Canberra
    Hey guys,
    Thinking of making a new box for my sub that will fit in with the contours of my boot more so than the big ugly cube I have at the moment If i build a box to the same volume but a different shape will this affect the sound much?
    Simon
    Forever blowing bubbles.
    Nope not at all... only need have readjust the amp. What size is your sub?? Are you thinking of porting or enclosed?
    Here are some on my work for inspiration.
    If you need Fiber glass let me know. I still have load.
    Jul 2007
    Canberra
    It's a 10" JL Louis. The first pic is exactly how I want to do mine! Need to get the big ass cube outta the way so I can actually carry things in the boot LOL. Thanks Louis
    10" would be fine just like the first one. If you are not looking for breaking SPL records, that space will work just fine.
    have I mentioned fiberglassforums.com to you.. if you are looking into fiberglassing. They are really helpful.
    Any sort of material you use try to keep air leaks to minimal,especially at the mounting surface, otherwise you will get ugly farting sound.
    Jul 2007
    Canberra
    Thanks Louis, probably going to use MDF, I like it's sound qualities Probably much harder to work with in that shape but i'll see how it goes.
    There's enough farting in general without making my stereo do it also
    I think I used 12mm MDF for the face piece, hardest part would probably be cutting to conform to the shape of the boot, a piece of foam and cutter to trace put the shape, possibly much more work. Nevertheless, have fun and be creative.
    make a mould out of fibregass to utilise teh space you have to its maximum potential, the curves of the inside of your boot will give it the strength it needs
    also check out the MEA forums, heaps and heaps of info on there as well of some build threads to give you some inpiration http://www.mobileelectronics.com.au/
    cheers, dan
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    Feb 2007
    It will effect the sound depending on what kind of box you have now. The effect wont be dramatic though.
    MK1 GLS 3door
    A4 B7 2.0T
    Jul 2007
    Canberra
    Thanks for the help guys, will keep you updated if I ever get round to it
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Soundofav6 View Post
    If anything mine sounds MORE awesome in it's new location...
    once again, beautiful work Louis
