Results 11 to 20 of 21
Thread: my retro esky swap
    Nov 2005
    cheers guys, yeah ill be porting it with a 50-60mm hole, that will also be hidden up against the car wall
    dom
    great idea !!!! I would suggest to seal the lid with silicon. The lid may vibrate than causing it to "fart". See how you go !!! great work.
    Nov 2005
    the lid has a rubber ring around it so its sealed, dunno how tight itll be but its is sealed
    dom
    Feb 2007
    Lol @ Stu's sub. I pumped the shiz out of them.
    I was going to do it in a leather suit case but it wouldnt have been enough bass for me. I got the idea from a mk2 with the same thing. There are a few wagons i have seen with the esky idea. Its great because its prity solid and there is plenty of room in there. You should seal it up with liquid nails or something so air doesnt rush out of the lid, if that happens it will sound bad (not like that 8yr old kicker soundes any good anyway).
    I wouldnt put the amp in the box, it will heat up and being an esky it will retain the heat and stuff the amp. Mount the amp on the back of the esky, out of sight. Porting is a little bit more complicated than cutting a hole. If you get me the inner dimensions of the box (and if your using that sub) i can do the maths and i can get you a port that will work properly. If you dont to it properly you can make it sound rubish.
    Instead of the suitcase idea i couldnt help myself and i went big..and brown:
    MK1 GLS 3door
    A4 B7 2.0T
    Nov 2005
    well i aint tooooo fussed on sound quality, ill be still using my Orig am/fm radio from the car, its more fashion over function.... but itll still work
    dom
    Feb 2007
    Another thing, you cant use the sub and port to cool the amp. The sub sux and blow (lol) so there is no air actualy circulating properly.
    MK1 GLS 3door
    A4 B7 2.0T
    Nov 2005
    meh... its all good, as i said... its mostly just for fashion, i hate stereo's lol
    dom
    Down with this
    Reminds me of this sorta
    Jun 2006
    Orange NSW
    When you sent that pic to me today the boys at work thought it was pretty different. Apart from the usual "Your gay VW buddies from Melbourne" comments, they thought it was pretty cool. hahaha.
    Nov 2005
    hahaha thats a pissa preen
    ohh i also forgot to mention that it still has enough room for a 6 pack!!
    BEST!
    dom
