Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 91
Thread: MK5 stereo install advice
  1. #21
    Jan 2008
    Sunshine Coast
    Lads, DD's and the RE's look great ( very hot little subs! ), but Mr C is on the money with the G510, 14.8 Litre sealed box! Wow.
    The others recommend at least a cubic foot - 28L.
    I think we have a winner.
  2. #22
    Feb 2008
    Auckland NZ
    the RE8 should set back around $199ish.
    it works in boxes from as small as 6 Litres, but i would recommend around 10 - 13 litres, blends in with the front alot better IMHO.
    Never heard of the G510, i think i'll do some investigation on that.
    Audi S4 (2001) - Imola Yellow
    Secret Project
  3. #23
    May 2007
    Moonee Ponds
    Smile
    Hey Charisma, Glad to see you here ! (CAA)
    I have a G5 in my Bora and it sounds pretty good. My only complaint is that the extra weight really affected the handling so I have pulled it out for now. The plan was orginally to have two G5's running off my amp each seeing 1400 W's in parallel but I might neg on that.
    Anyway's all I can say is I think you will be happy with the G5 and I would love to hear your thoughts on the radiator when you get it.
    Good thing with the matting but remember not to use to much if you want to keep the car somewhat sporty.
  4. #24
    Feb 2008
    Auckland NZ
    For what is worth, this is what i did for a guy in his Bora.
    Secret Project
  5. #25
    Jan 2008
    Sunshine Coast
    Awesome info guys, and Glidn that's exactly where my thoughts are going. Nice install! Just keen to get the volume correct, obviously easier in a regular box. Have to somehow try to tie in the radiator if i go G5, just cause you can!
    I agree overkill with dynamat is unecessary ( for my needs anyway... ), and other parts are coming out, so the weight gain won't be too great. I have a large box full of "extra" bits out of the car already. As for "sporty", I'm planning on tweaking more than just the stereo. Visited my friendly APR guy today to get some ideas.... : )
  6. #26
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by glidn View Post
    You love the RE hey!
    Won't rule it out, as it would certainly be light, and that is always a plus for the twisty stuff. I'd guess it'd be a lot shallower too, easier to fit in glidn's pic example above. Cheaper too, let me get other goodies quicker!
    Thing is in the performance vs volume ratio, what beats the G510?
    I've got a very modestly rated 500RMS to feed a sub...
  7. #27
    Feb 2007
    Central Coast, NSW
    Quote Originally Posted by qsilverza View Post
    lol are you stalking me. Yeah thought I better off load some of my knowledge, or lack there of
    The G5 10inch should be fine, I would also recommend something like:
    Oz Audio Me 10.2
    Treo TSX 10inch
    Hertz HX250
    Either one of those 4 will be fine and loud in a sealed enclosure. When I had the G5 it would blend in awesomely if I had some 7 / 8 or 9inch mids. However only having 6.5inch mids the Oz Me that I replaced it with has a lot more punch but not quite the rumble.
    Does your car have that flap on the side for the first aid kit? That would be the perfect place to do something similar.
    Bora has gone ;( Custom sub box and beige floor mats to suit for sale.
  8. #28
    Feb 2008
    Auckland NZ
    Haha, yeah i like the RE8 more for the Fact that it not only goes insanely loud without all that much power. And secondly it requires the least space for a sealed enclosure that i came across against anything else.
    I'm currently running 2xRE8 at around 500 - 700WRMS. And they are doing a remarkable job.
    I use to run a single RE12, only at a mere 300wrms, and i actually took it out of the car about 3 days later. IT was way to much, it just had way to much kick but it too blended nicely, was not sloppy and all that. But LOUD SQ or stupidly LOUD SPL, it did a great job. But again i need the space in my car.
    Hence the RE8 fit the bill in all catagories. Small Sub, Small box, does not need massive power, loud output and it does not cost all that much.
    But they do 10 and a 12 if you really want. and the RE audio - RE range is the entry level subs, and the 5 more levels to go up to.
    Well the Boston G510 appears to be one very nice sub, but it defeats the purpose of a small sealed enclosure for the size of the magnet. It volume in the box maybe tiny. But way to big IMO.
    I did hope someone in NZ would have done Hertz or Oz audio, but alas no one do these either.
    But the likes of the morel and that, just simply ship from the states.
    Secret Project
  9. #29
    Jan 2008
    Sunshine Coast
    Ahh, so THAT's what that strap thing is in the boot, a first aid holder. Couldn't work it out! That'd be the side, for it's opposite me for weight distribution as well.
    Great ideas, and Glidn, you're right about the depth of the bigger speakers. I'll do some measuring and cardboard mockups, and get serious about the space I can afford, THEN find the sub to suit. Otherwise it's just piss!ng in the wind...
  10. #30
    Jan 2008
    Sunshine Coast
    OK, I've played with the tape measure and putting in even a shallow 10" would be a mission to keep it nice and level with the wheel arch. I'm even wondering where the heck to put the amp I have! Space is the major factor for me, I may dream of a 12" in a box, but I know it will spend a lot of time out of the car, which defeats the purpose.
    Seems the left side would give a "box" volume around 10-13 litres if I do a bit of metal work for the magnet.That RE8 is starting to look pretty good.
    I've heard these Hertz speakers mentioned like gods before...are they REALLY that great, or is it the old law of diminishing returns?
