Page 1 of 10 123 ... LastLast
Results 1 to 10 of 91
Thread: MK5 stereo install advice
    Jan 2008
    Sunshine Coast
    Hello all,
    I'm going to purchase a golf in the next several weeks, and the one mod I want to do first up is put a decent sound system in it. Having done several systems over the years I pretty much have that side under control, but wondered if anyone who has done one in a mark 5 could give me any up front advice as to things to watch out for, tips and tricks, basically the hindsight side of an install. I hear there are plenty of things to rattle....
    I aim to replace the head with a current Alpine, run the front 6" splits and 12" boxed sub off a 4 channel amp, and drive some reasonable 6"ers in the rear shelf straight from the head for fill. I will run stand-alone power wiring, to and from an audio specific battery. I'll be dynamatting everywhere along the way.
    Anything in particular that rattles or is tricky to get apart / breaks easy?
    Always nicer to know up front
    thanks for any advice!
    Feb 2008
    Richmond, VIC
    In the FAQ section, the first link is how to remove the stereo, has lots of pics etc to give u an idea what to expect.
    http://www.vwwatercooled.org.au/newf...ead.php?t=7059
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Jan 2008
    Sunshine Coast
    Thanks Steve,
    Thanks for that and it is indeed very helpful, and it sounds like the dash is a bit flimsy, so good to know up front.
    I'm mainly wondering how aftermarket speakers fit in the doors, does the door opener rod rattle, is the car going to flip out if I remove the radio unit, stuff like that.
    anyone?
    Jan 2008
    Melbun
    Quote Originally Posted by cogdoc View Post
    Thanks Steve,
    anyone?
    to make your life easy i suggest getting a face plate that converts the unique golf size slot into one double din or two single din slots. sorry thats all i can suggest
    2x Caddy, 1x Ducato
    Feb 2007
    Bunyip, Victoria
    Hello all,
    Why are you using a second battery for just one amp, and a VERY basic install?
    Unnessesary.
    I'm using 2 amp, (4ch and mono, both very powerfull) On the standard battery with no voltage drops on 4 gauge cableing. While dynamat is usfull, I don't belive it nessesary on a MK5 with just splits and a 12".
    I have a set of 3 way splits, a set of 2 way splits and a set of co-ax in my MK3 with no dyamat, and it sounds fantastic. Why not put the rear speakers in the standard speaker locations? Thats why there there. Trust me, avoid cutting into the shelf. Makes it look dodgy.
    Jan 2008
    Sunshine Coast
    Hey Science, thanks for the reply.
    Great to hear that you figure Dynamat is uneccessary. That answers my main query.
    Sorry it seems my first post wasn't clear, but I didn't want to go into boring detail just to ask if stuff rattles or is easily broken. I will be dynamatting the car anyhow, as I simply see the benefit. Glad you are happy with your setup.
    It might "only" be a 12" but it's a Boston G5 with a 12" radiator....so it tends to make things rattle.
    I will be replacing the stock battery with a deep cycle audio specific one. Whilst my install is indeed simple that one amp is a bit of an old school monster, and it does not like a voltage drop at all. Puts out some good RMS numbers on the meter though! Plus I've already got the battery....
    I will be using the stock rear holes and not cutting any metal. It's just fill from the rear anyhow.
    Thanks guys, I just need the car now!
    Feb 2007
    Bunyip, Victoria
    sorry, at first you just sounded like the noobs i deal with in other forums with FULLY SICK VN commodores, who just want there sony 12" to pop out the windows, but then they also want it to sound good. And it's never going to do either. I like the boston G5. Good crisp sound, and i'll be keen to here your thoughts on the radiator. I have seen them, but never heard one used.
    As for the rattles, i think your pretty safe with the MK5, they are very well bolted togther.
    As for the battery, i thought you where going twin batterys, that i definatly can't see the point of for a small install.
    Jan 2008
    Sunshine Coast
    Hey science, no probs, I know what you mean. I never talk stereo even though I love it, cause you always end up talking to some goose who mentions that their speakers are high wattage and thus way louder. A lot of misinformation out there.
    Once it all goes in, I'll give you my opinion, for what it's worth!
    Feb 2007
    Central Coast, NSW
    Dynamat is a neccessary evil. You will need it. I used a bulk pack plus 2 sheets in the bora. Don't forget about Dynasorb behind your mids ( or Focal chant )
    Prepare for rattles dude. I had one of those running off an Audison SRx2s and everything shakes. In the old car it was much much worse. Look forward to very low extension. I have since replaced mine with a OZ ME 12.2. Wanted something with more punch.
    I will be replacing the stock battery with a deep cycle audio specific one. Thats a great idea dude. I run an Optima D34M and a 200A earthing kit. No cap needed with good earths.
    Good luck with it all. Be very careful of the clips, for some reason they break very easily in the VW's. Other than that my install was fairly straight forward.
    Bora has gone ;( Custom sub box and beige floor mats to suit for sale.
    Feb 2008
    Auckland NZ
    you can run either the JL audio CSX-635 i think from memory, they have the 3 way set, so you can utilies all 3 speakers in the door.
    or you can run with the entry level focal 3 ways from memory there 4inch is also shallowish.
    For the mid you cannot realistic run larger than a 47mm depth for the 3 - 4" mid.
    With the 6" mid you can run up to a 7" which a mere spacer.
    but do remember to seal the door with dynamat or hushmat or anything like that. You will thank yourself in the long run.
