Hey all,
I've been thinking a bit about RVCs for MK5 Jettas. I know of the OEM badge cameras that can be fitted to golfs with a little sheet metal removal and the boot handle camera install, like this:
VWVortex.com - OEM rns510 reverse camera for jetta: DIY
There seems to be a bit of a lack regarding MK5 Jetta installs specifically. So... I was chasing a bit of information, If I can get a couple of answers then I thought I'd try a different install and do a bit of a write up on here about it.
I'm thinking of placing a camera that replaces one of the number plate lights, this style:
Car Rear View Reverse Backup Parking Camera for VW Touareg Volkswagenv SKODA | eBay
- I was hoping I could get a camera and then an OEM wiring loom, change the connection over and plug it straight into the back of my RCD510. That means the new camera would need the same video format as the OEM. Does anyone know what that format is?
- If the format is different, I assume I'll have to get a converter then change its connection to the OEM 26pin. I'd hope that's reasonably simple once I know the two formats.
- Alternatively I was thinking I might be able to retrofit a OEM camera into the plastic housing above, not sure about this yet. I might consider it if someone can see a problem with my first idea.
That's seems to be all that's needed I think. It will require a bit of playing with wires but from what I can tell I should be able to get something that looks reasonably genuine without having to get the angle grinder and silican out.
Can anyone see any problems with this?
Walter
