Results 11 to 20 of 29
Thread: MK5 GTI - RCD/RNS510 installers (Brisbane)
    May 2012
    Quote Originally Posted by 99_FGT View Post
    Sorry, I quoted it really badly
    The antenna adapter may be needed, basically on the older units there are two distinct fakra antenna plugs, on the later units they have a twin plug. This can be fixed by trimming about 3mm of plastic shrouding off one plug.
    The reverse camera input is the 26 pin plug I referred to.
    Al..
    Hi Al,
    No worries, can you tell from this pic?
    Genuine VW RCD 510 6 CDs Head Unit Stereo for Golf Jetta EOS Passat Tiguan Polo | eBay
    Nov 2012
    QLD
    That is the standard antenna connector for the 3rd gen radio. You need to pull your original radio out to see what connector you have.
    if you're near bulimba you're welcome to drop over of an afternoon and pry your radio out for a look. I have required tools.
    May 2012
    Quote Originally Posted by Tom87 View Post
    Hi Tom,
    Thanks, I guess I will see for myself when I go to install it (likely on the weekend). If I do need the adapter I'll just order off ebay would be easiest or have to get from VW suppose.
    Thanks for the offer, I'm not far from Bulimba so if I get stuck I'll give you a yell.
    Joel.
    May 2012
    Do I need to disconnect the car battery while installing the new radio?
    Nov 2010
    Burpengary, Queensland
    Quote Originally Posted by j_man View Post
    Not necessary to disconnect the battery. If you go with RNS510, I have a VCDS cable you can borrow.
    Mar 2009
    UMG Brisbane
    Re: MK5 GTI - RCD/RNS510 installers (Brisbane)
    You should be able to pick one up for less than that on here, or about the same but with the rvc plug. Plus, who would do something so horrible to a poor, innocent RCD 510 as put THAT song on it... Then again, think of it as rescuing it.
    Al..
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Pacific Paradise QLD
    Am looking at this one as it seems Ok
    eBay Australia: Buy new & used fashion, electronics & home d
    Or maybe one of these but it has RCA connectors
    http://www.ebay.com.au/itm/Volkswage...item27ced7e444
    May 2012
    Just another thought, I'm hoping I don't need canbus uprgade because mine is 07/MY08 but how do I know for sure, I don't my good new battery to die on me.
    Jun 2011
    Short of pulling out your CAN-Bus gateway, you'll need a VCDS cable to find out which version of CAN-Bus you have.
    Info on which versions drain the battery here:
    Can Gateway upgrades (Battery drain fix after RNS, RCD units install)
    Mar 2009
    UMG Brisbane
    I have never actually got confirmation of this, but I'm pretty sure that the MY08 cars that came with the full height MFD are fine from a canbus version.
    Al..
