ive got a RCD310 that came out of a 2011 tiguan, never used. have got the pin code supplied but not sure if its locked or not ...
PM me for a price, its very cheap !!!
just sitting here in a vw box in my garage , time for an autumn spring clean
agreed with the comment above, if you just want mp3 cd playback go the rcd310, if you want to use sd cards, go the rcd510....
your car is an 2005 model, not compatible with it unless you change the canbus ( module that controls the electrics) and then it has to get coded by a person who has a special cable for volkswagens called vagcom/vcds.
There are many threads to search up if you do get stuck ! pm
R
