Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MIB UI RCD510 in Mk5 Golf
    Oct 2016
    Christchurch, New Zealand
    Well, the unit arrived today. 4 days shipping from China to NZ, which is pretty good. The unit was packed well, and looks great.
    I'm just waiting on the antenna adapter and some trim removal tools, and I should be all set to install it later this week, or on the weekend
    Oct 2016
    Ok, I got the unit fitted. It proved to be a bit difficult to remove the trim, but I got there in the end.
    The unit functions great, and the audio/Bluetooth functions perfect.
    The only problem (and it is a minor one), is the when I put it in reverse, the screen switches to the RVC mode, and says "Look, is it safe to move?" and then switches to "Reverse Camera not fitted" or something like this. It only does it once after the car is turned on and reverse is used. Does anyone know if this is possible to be switch off?
    Apr 2015
    There might be some sort of way to disable RVC mode through VCDS?
    There is some coding to change. May not yet be documented in vcds as sellers I've seen are showing raw bytes to change.
