I had the same issue to fix you'll need access to vag com:
Then:
1. Go to channel 37 - Navigation and go to Byte 7.
Is the BAP enabled or disabled?
If it is currently enabled, please disable it.
If it is already disabled, kindly enable it.
2. Reboot your RNS510
And it should work (well at least it did on mine)
