Results 1 to 7 of 7
Thread: New RNS 510 advise
    Apr 2012
    Germany
    New RNS 510 advise
    Hey Guys
    i have Unite RNS 510 B version, i am thinking to have the F version or newer,
    can someone advise if i can use the C or F version with my Canbus Gateway?
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 F
    HW: 1K0 907 951
    Component: Gateway H10 0120
    Revision: H10 Serial
    number: 2800105C1097E4
    Coding: 3D3F0B08070002
    Why do you need a newer unit?
    I understand you have had some trouble with trying to get POIs working however its highly unlikely that it is a hardware issue.
    I would try and find someone nearby to you who has everything working to help you out.
    Apr 2012
    Germany
    thank you so much,
    i just got the possibility to sell my B unit and was thinking to get one of those new Unit with new Gateway,
    so was wondering if possible to have D or F unit working with my Can bus Gateway,
    about the POI i downgraded to 2xxx and my poi are working fine, so will wait till someone will have the POI working, than i will update to the new FW
    thank you
    You don't need to upgrade your CANBUS gateway, just use a firmware image that has the tables swapped to support older units. This has been done to [revent battery drain issues.
    Apr 2012
    Germany
    Thank you
    my only problem till now and still is the POI,
    so will hope someone get back to me with the Working POI databas
    Mindarie, Perth (WA)
    Quote Originally Posted by jamerson View Post
    Thank you
    No-one in Australia will be able to assist with that.....because of it being region specific.
    Apr 2012
    Germany
    Quote Originally Posted by FJ Steve View Post
    thank you
    with my Can bus and 3810 i can still use new Devices on my Car Like D or F...?
    because the batery issue is fixed on the 3810 i've heard?
