Found new map update on MIB-Helper.com
Version: MQB platform with 9.2-inch display (a.k.a. MIB2.5)
Trade Name: VW Discover Pro
2025 ROW (MRM: full) (14.7 GB)
https://vw-maps-cdn.lighthouselabs.e...S5MIBH3_ROW.7z
Mibhelper knows nothing about my T-ROC MIB. HW H22, SW 0306 Navi 21.11
2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
2023 T-ROC R - Sunroof, Black Pack, Beats Audio
There is a newer version available for you.
Map is about 18 months old but that is the current version we have in Australia for now.
Here is the direct link for the download - https://navigation-maps.volkswagen.c...ine_Update.tar
Flipper Dog
Now - T-Roc R, Audi Q5
Well have tried to install it the way I usually do and so far no luck Put it in the car and let it idle for 40 mins with no luck.
last map I unzipped it to the root directory of the USB C stick I have 1200 music tracks on and last time it installed by its self as usual. Deleted that map and put this version on but no go so far.??????????????????????
Your USB stick should be freshly formatted in Windows with NTFS or EXFAT.
You should use 7ZIP in Windows to unsip the files to the root of the USB stick. NO other files.
Put USB stick in and turn on ignition, don't idle for 40 minutes, that's bad for your engine and your fuel bill and doesn't help the update.
There is zero feedback from the system as to progress, which annoys the crap out of me as an IT person, but eventually you will be rewardes with a map version later than you had. Even then, other system updates could still be happening, they say it could take 4 hours.
I succeeded with mine, and my observation was that even when the map file showed newer, the system was quite laggy for some time afterwards. I put my charger onto the battery for the duration and left it for 3 or 4 hours to do it's thing.
Mate have been doing it in VW for 14 years and in Mib 2.5 since 2019 ad Mib 3 since 2021. It ALWAYS WORKED (except once my fault) This time it hasnt Im well aware of requirements for formatting etc.. The last few maps i installed in the KAMIQ I stuck on the stick as i said above and it has worked for several installations. Im not worried about 3 poofteenths of fuel it used, is far better than it sitting there with the ignition on running the battery down and it usually only takes 20 mins to install and yes it doesnt say anything.
In Australia other updates wont be happening as we are not connected to the net and all that can be entered into the system is what is on the USB card, So no firmware updates.
I have yet to find a newer firmware than my 0278, which would also need a SD card to install. I never use 7 zip, have used Win RAR for years without problems. The reason for the lag is that you should go for a drive and let it reorient itself , as you had to with the old RNS 510
Flipper Dog usually gets the correct maps and Im sure its the right one but something is not quite right I had to remove the old map off the stick to put the new one on and it had installed fine and the 1200 music tracks have been on it for 3 years and not prevented maps from loading until now, if in fact it is them and no reason they should as not done it before. my MIB serial is 2G90 35876D in a Skoda
