Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 125
Thread: Map updates - Discover Pro
  1. #21
    May 2018
    Sydney NSW
    I ended up figuring out how to update my maps to the 2018 maps that came out early this year, by using the service menu (SWDL option)
    However today I downloaded the more recent 2018 and I am not able to update, either by the service menu or the conventional method.
    Maybe I need a newer firmware or something?
  2. #22
    Jan 2013
    Quote Originally Posted by LimestoneR7 View Post
    You either need a new firmware or someone who can check your settings with VCDS or OBDeleven and enable few locked options.
    I have the same problem as you. Well, partially, as my "brand new" (demonstrator) Tiguan came with an official VW SD card in slot 1 and I was able to update the latest map (1010) by downloading it separately and copying it onto the SD card.
    However I cannot add POIs. I have the same issue like you. I followed the instructions but my Discover unit says I can add POIS with software upgrade and does not see the POIs on the SD card. Odd.
    I asked someone to have a look at my VCDS settings and enable few things, that might help. Maybe you should do the same.
  3. #23
    May 2018
    Sydney NSW
    I've recently bought a OBD11 but I'm completely unable to access the infotainment unit to activate Traffic Notices and other stuff. Another forum member had advised it is most likely that my retrofitted MIB1 unit was hacked at the time of installation so that it doesn't trip the VW component protection system.
    It can be fixed but basically I'd (or really some one who knows what they are doing) have to figure how the infotainment unit was hacked, reverse that if possible and have the unit reinstalled "properly" by a dealer so that the retrofitted unit is registered, seen as not stolen and linked to my VIN. Alternatively I can dispose of the infotainment unit, acquire another one and have that one properly installed from scratch. Either way including installation etc will cost a fair bit of money. If I was going to do all that I may as well sell the car and get a near new R Grid. But I'll just have to live with it. I can supplement any limitations with the GPS with my smartphone.
    From what I've been told, if the Obd11 can't read my infotainment unit, VCDS won't either, for the same reason as explained above.. Happy to be proven this is wrong though
    Incidently I can now load POIs. It was simply a case of copying the MIB STD directory only to the SD or usb drives. Instructions on this forum and elsewhere had said we copy from a different directory but that may work for MIB2 units only.
    In any case I don't get a warning sound for the speed camera POIs which was the whole point of the exercise so it's basically useless.....
  4. #24
    Jan 2013
    Are you saying that on the SD card under the PersonalPOI directory you have only the MIB2TSD directory, nothing else? Or you only have the MIB2TSD directory, nothing else?
  5. #25
    Need more information.
    It's highly unlikely that an mib1 would be hacked as there would be no point.
    Mib2 are modified to be installed in place of mib1 systems.
    Even then they can be accessed via diagnostics. If it's a discover pro then you need to go into the GEM green engineering menu, disable dab, enable diagnostics then reboot.
    And vcds can access a unit by can address (5f) for infotainment manually where obd11 needs to be able to see it from the canbus gateway installation list.
  6. #26
    May 2018
    Sydney NSW
    Quote Originally Posted by PeteC View Post
    I only had the sub directory and the single file that are within the MIB2TSD directory, and nothing else, on the card.
  7. #27
    May 2018
    Sydney NSW
    What information would you need? I was advised on another forum that it was likely (but not a certainty) that my MIB1 was hacked, nothing more or less, given that the 5f component group on my Obd11 was inaccessible.
    As my car is a MY2015 R it originally had a Discover Media unit with a smaller screen and the GPS ran off a SD card.
    Anyway if I go into the engineering menu and make the changes you suggest, would it be then likely that the Obd11 can then access the unit? And if so do I then have to reverse the changes in the engineering menu afterwards?
  8. #28
    What is the part number of the unit?
  9. #29
    May 2018
    Sydney NSW
    Device part number is 5E0035020C
    Hardware is H42
    Software is 0389
  10. #30
    OK that is a Skoda Columbus part number. It's the same as a Discover Pro MIB1...I guess they really wanted DAB.
    So you should be able to enable diagnostics by going into the GEM, disabling DAB and enable diagnostics for next 5 reboots.
    Once you've accessed it via diagnostics you can enable DAB again and it won't be contactable again.
