Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 111 to 120 of 125
Thread: Map updates - Discover Pro
  1. #111
    May 2018
    Sydney NSW
    Quote Originally Posted by petemac110 View Post
    Grab the previous Rest of World 2024 update here, which is the 'full fat' file:
    Columbus Map Update 2024 (MIB1/2 HIGH) - Audio, Electronics and Security - BRISKODA
    Thanks. All good. Let's see how the next update goes.
  2. #112
    Aug 2024
    Found new map update on MIB-Helper.com
    Version: MQB platform with 9.2-inch display (a.k.a. MIB2.5)
    Trade Name: VW Discover Pro
    2025 ROW (MRM: full) (14.7 GB)
    https://vw-maps-cdn.lighthouselabs.e...S5MIBH3_ROW.7z
  3. #113
    Aug 2021
    Quote Originally Posted by rayvos View Post
    Legend!! Many thanks. Updated my MY18 Passat this afternoon.
  4. #114
    Dec 2007
    Mibhelper knows nothing about my T-ROC MIB. HW H22, SW 0306 Navi 21.11
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
  5. #115
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by gerhard View Post
    There is a newer version available for you.
    Map updates - Discover Pro-map-data-23-6-jpg
    Map is about 18 months old but that is the current version we have in Australia for now.
    Here is the direct link for the download - https://navigation-maps.volkswagen.c...ine_Update.tar
    Flipper Dog
    Now - T-Roc R, Audi Q5
  6. #116
    Pacific Paradise QLD
    Quote Originally Posted by Flipper Dog View Post
    Just checking thats for an MIB 3 as it looks like it and last mao was 21.12
    Thanks
  7. #117
    Dec 2007
    Fantastic! Thanks for that. Mine has the same 3G9035876D so the update should be seamless
  8. #118
    Well have tried to install it the way I usually do and so far no luck Put it in the car and let it idle for 40 mins with no luck.
    last map I unzipped it to the root directory of the USB C stick I have 1200 music tracks on and last time it installed by its self as usual. Deleted that map and put this version on but no go so far.??????????????????????
  9. #119
    Dec 2007
    Your USB stick should be freshly formatted in Windows with NTFS or EXFAT.
    You should use 7ZIP in Windows to unsip the files to the root of the USB stick. NO other files.
    Put USB stick in and turn on ignition, don't idle for 40 minutes, that's bad for your engine and your fuel bill and doesn't help the update.
    There is zero feedback from the system as to progress, which annoys the crap out of me as an IT person, but eventually you will be rewardes with a map version later than you had. Even then, other system updates could still be happening, they say it could take 4 hours.
    I succeeded with mine, and my observation was that even when the map file showed newer, the system was quite laggy for some time afterwards. I put my charger onto the battery for the duration and left it for 3 or 4 hours to do it's thing.
  10. #120
    Mate have been doing it in VW for 14 years and in Mib 2.5 since 2019 ad Mib 3 since 2021. It ALWAYS WORKED (except once my fault) This time it hasnt Im well aware of requirements for formatting etc.. The last few maps i installed in the KAMIQ I stuck on the stick as i said above and it has worked for several installations. Im not worried about 3 poofteenths of fuel it used, is far better than it sitting there with the ignition on running the battery down and it usually only takes 20 mins to install and yes it doesnt say anything.
    In Australia other updates wont be happening as we are not connected to the net and all that can be entered into the system is what is on the USB card, So no firmware updates.
    I have yet to find a newer firmware than my 0278, which would also need a SD card to install. I never use 7 zip, have used Win RAR for years without problems. The reason for the lag is that you should go for a drive and let it reorient itself , as you had to with the old RNS 510
    Flipper Dog usually gets the correct maps and Im sure its the right one but something is not quite right I had to remove the old map off the stick to put the new one on and it had installed fine and the 1200 music tracks have been on it for 3 years and not prevented maps from loading until now, if in fact it is them and no reason they should as not done it before. my MIB serial is 2G90 35876D in a Skoda
