Magic Dynaudio Amp Signal
I've upgraded my factory Dynaudio system (B6 R36 Passat) to add a 12" sub and am having some odd issues with the Factory Amp rejecting input signals...
Here's a diagram of my system:
The aftermarket DSP is added between the RNS510 head unit and the factory Dynaudio amp (3C0 035 456 J). The design is for the DSP to create the new sub channels and apply frequency filtering and time delays to the existing signals before the Dynaudio amp/DSP applies it's own passat-specific tune. The DSP pre-processing brings the sub 'forward' more (by delaying the existing signals) and allows the sub to take over the lower frequencies - so I can push the bass harder without bottoming out the factory speakers.
For some reason, the Dynaudio amp only accepts the signal if the Front-Left speaker input is either connected directly the the RNS510 head unit (RCA joiner F-F), or indirectly via a y-split (RCA 1M-2F)...
I've used multimeters to test the head unit and dsp output voltages and to ensure the connections on my (custom) wiring harness go to the right pinouts (also tested the harness by bypassing the DSP altogether). The aftermarket (Helix) DSP software is showing input signals and outputs to the sub amp fine... I even resorted to using headphones via an RCA adapter to listen to the input/output signals.
Everything tests fine, accept for the Dynaudio amp rejecting the DSP signal if the Front-Left signal isn't connected directly to the amp. It seems a though there's some magical signal being sent to the Dynaudio amp from the RNS510 head unit that is being filtered out by the aftermarket DSP...
Here's a graphical summary of what the Dynaudio amp accepts/rejects:
Does anyone have any knowledge/experience with this and ideally know how to get it working?
