Results 1 to 10 of 16
Thread: LED globe error light
    Jan 2015
    Brisvegas
    Hi all a bit of a strange one, i am making my way changing all the globes in my mk6 over to LED globes but I keep getting an error light for the number plate globes- I have put 3 different sets of led globes in all Canbus/error free globes off eBay but it still puts up error lights on the dash. If I put back in the standard non led globes no error. Each of the globes are from different sellers both in China and Australia.
    Is there a special resistor required for the number plate LEDs??
    Thanks
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by MozzGTI View Post
    Thanks
    LEDS run lower voltage then standard bulbs thus your monitoring system is thinking the lights are out.. I can't remember what the fix for this is (been awhile since I've seen this issue) perhaps someone can give you a better insight..
    Jan 2015
    Brisvegas
    Thanks Dubber was aware of that and that's why I had brought special LEF globes with resistors to prevent the error messages. I had other LED globes in the car with no problems/errors messages, just having issues with the number plate lights.
    Dec 2008
    Sydney/Canberra
    Not lower voltage, less resistance.
    I'm pretty sure you need to do some coding with VCDS to get them to work correctly.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2011
    Point 4 of this post for the Mk7 perhaps?
    VCDS (VAG-COM) codes and programmable options for Golf Mk7
    If it's not right, then it's buried in this thread probably
    LED Number Plate Lights
    Mar 2013
    Brisbane QLD
    You should be able to disable bulb monitor for the number plates on mk6..can on mk5. PM me if you want me to have a look for you.
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Erskineville, NSW
    have a look in Lucas_R's thread on his GTI. He bought some LED number plate lights from the USA & they are well made & error free.
    Nov 2009
    Quote Originally Posted by vdubmotorworx View Post
    I don't believe you can, no.
    I bought these, did the trick perfectly:
    Volkswagen â–º Plug&Play CanBus Adapter â–º VW LED 1K8943021C â–º 1K8943021 Golf Polo | eBay
    brisbane
    i went through 3 sets of so called "error free" number plate lights until i found a set that actually worked...
    as stated above its probably a good idea to get a brand that has already been proven by another forum member...
    Mar 2013
    Brisbane QLD
    Quote Originally Posted by AdamD View Post
    Im sure it waa a mk6 that i turned off No plate lamps but couldnt turn off LED tail lights
