just having a quick glance it looks like the HP is set too high on your amp driving the speakers. depending on the individuall brand type of speaker, generally soeaking the HP should be set in between 60 and 120 Htz, although as i said this is a generalisation and could move either way from this... lowering this crossover point will give you more midbass, however you will have to play around with the gain so that they dont start bottoming out... from the information you have given you HP is approximatley around 180htz, so as you probably can realise lowering this will open up the midbass a bit more...
as long as you are still running the standard crossover you wont damage your tweeters by setting it too low (this is always a danger when running components fully active), however i would advise that you start off with low volumes as the midbass will start distorting and potentially damage them if you go in 'too hard too fast'... trial and error is the key...
also what type of HU/processor are you running? if you are running something basic you may well find that upgrading this will give you a much better sound due to the more detailed tuning features... let us know what you have...
cheers, dan
1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
