Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: It's time for a major overhaul of Skoda (and VAG) ICE systems
  1. #51
    Quote Originally Posted by brenno View Post
    Hopefully it won't be too long until head units start supporting Airplay. Perhaps VW can surprise me. Seeing the iPad being integrated in the Kombi concept car recently certainly raises hopes.
    That's where I started way back too. The Kombi with an Apple friendly heart.
    Love and Peace.
  2. #52
    Jan 2008
    Did…..you…..mean two for data?
    No I didn't, Apple changed the pins on the apple connector that were used for charging and made further changes to the requirements for charging after that to preclude non Apple chargers.
    OK, so since the changes are made at the Apple 30pin end then the scenario I mentioned above should work. I'll go through it in simpler terms.
    No they won't.
    Standard USB port --> Standard supplied USB iPod cable --> iPod.
    This setup supplies power.
    Incorrect
    - USB port on a computer where there is resistance on the data pins will supply power.
    - USB port on a charger from Apple or updated aftermarket supply that has a resister across the datapins will supply power.
    - USB port that does not have the data pins connected or has no resistance on there will not work.
    VW MDI to USB cable ---> Standard supplied USB iPod cable --> iPod.
    This setup does not supply power.
    That setup is not designed to work, the MDI to USB cable is only for mass storage devices and not for the control of the iCrud. It clearly states this in the MDI user guide.
    The VW MDI to iPoo cable will charge the device and it will control it as well.
    Now….given all the Apple voodoo pinout trickery and signal across data pins has been retained by the same known good cable, why does this not work? I mean, if it were a standard USB port to standard specs, it should supply power on the pins right?
    The standard USB port on the MDI does offer up 5V and the iTurd can see this 5V however it will not charge because there is no resistance on the data pins. Once again this is because Apple decided to only charge their devices from Apple supplied accessories or via a computer. Apple are the ones who are not following the USB specifications here not VW
    Oh I'm aware that other manufacturers have the same issue. I'm sure there are vehicles out there in a worse position . I'm also fully aware of those that seem to have no problems at all.
    Everyone who created devices over the period when Apple decided to change specifications had problems, many devices had to be turfed out because you couldn't upgrade or fix them so don't try and make out like some companies had no problems when they all did.
    I guess this is as perfect a time as any to subtly point out that none of these problems with changes to pinouts would exist if you were able to use the original cable that came with the respective devices
    Yes they would, plug in your genuine Fanboi cable into a standard 5V USB power supply and watch it sit there and fail to charge.
  3. #53
    Jan 2007
    Quote Originally Posted by Maverick View Post
    Oh I get it now. Weren't those changes made years and years ago now? Ample time to react I think.
    I had no idea the non Apple charger I am currently using to charge my device is not able to charge my......oh wait.
    Incorrect
    So, you're saying the data pins on the MDI to USB cable are not connected and/or have no resistance? Wow, that is quite telling. I didn't realise it was that easy to implement.
    Does your user guide have sticky pages?
    That's a little strange because I have been able to charge my device on the USB port on all sorts of devices that don't support the connection of iOS devices. The port on the back of a Foxtel box, a cheap Kogan TV mass storage port, a router mass storage port, a Sony PS3 all charge the device. Hell, even the old Brother MFD manages to power a device via USB. These are all devices that have no reason whatsoever to connect to an iOS device, and by your definition should not work, but they do. The VW MDI 'USB' port is the first one I have encountered that doesn't work....not even to supply power.
    Yes I remember. They all worked fine with the devices they were designed to work at the time though. The changes didn't affect me. Perhaps it was because I used a USB cable on all devices.
    I've only found one that *doesn't* work
    Looking forward to better integration with the next VAG product. Crossing my fingers for Airplay.
  4. #54
    Jan 2008
    Clearly you're trolling as no-one can be that....
    Trolling again, think about what you said for a second. If the MDI to USB cable did not have the data connections connected it would not work at all. What I said was there was not the resistance there that Apple expect to charge and as I also said that adapter is not designed to have a Apple iTurd cable plugged into it
    Once again you can't even comprehend basic information, you and Apple are a match made in heaven
    Why don't you contradict yourself again, one minute the usb port is a great idea and the next it's not. Did you think for a second what would occur if the usb port in the device you were plugging in to didn't have the resistance that Apple required to start charging? Oh that's right you had to toss it away. See once again why the MDI is a good idea? Nope well I figured that you wouldn't because you're too busy trolling to see that Apple are willing to change their standards without notice and having an inbuilt USB port on the device you're connected to can mean your're stuffed.
    Good for you
    Go and buy one of the other cars that has "better" integration and that lets you use the "cable" that came with your Apple product, I'm sure they will support Airplay
  5. #55
    Jan 2007
    It's not trolling Matt. It's just a different opinion to things. We obviously have different approaches and have different devices. I appreciate you like the system, and I can see it works well for someone like you. It doesn't work well for everyone though. I'm glad this thread popped up, as it seems I'm not alone.
    Cheers!
  6. #56
    Well looks like JetStar love iPads too,...
    Australia based Jetstar, the low-cost subsidiary of Qantas Airways, reported in their April 2011 flight magazine that the introduction of iPads as the airlines main source of in-flight entertainment was "imminent". Resultantly, Jetstar have ordered 'Pinnacle' slimline seats manufactured by B/E Aerospace to be installed in the company's new fleet of 44 A320 aircraft; these seats will contain a bracket that lets passengers hang the iPad at eye level. The airline will also retrofit around 25 existing aircraft with the new seats during mid-2011.
    Jetstar has customised the iPad's software, developing its own graphical interface and content management system for the device, in order to make it viable for in-flight entertainment. Containing movies, TV and music, the devices are protected by a tough custom case which houses a second battery therefore boosting battery life to approximately 20 hours.
    [source: ]Movable Type | Movable Type
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  7. #57
    Jan 2008
    Quote Originally Posted by 77kw polo TSi View Post
    They also like hiring pilots with 200 hours fly experience for $57,600 a year and recruiting flight attendants from Thailand on $437 a month so your argument is that the iPad is great and VW should support it because a cut price low end cheap arse airline uses it?
    In the Automotive world JetStar sits at the Hyundai/Great Wall level.
  8. #58
    Jan 2007
    Do you think VAG should avoid any further progression on iOS integration with their cars?
  9. #59
    Hmm?
    Is that like saying VW shouldnt build Polos in Poland or East Crackoff where labour is cheaper.
    Would you be saying that VW or SEAT / SKODA is the arse end of the VAG group ?
    I'd think you'd find Aeroflop would be nearer in accuracy than JetStar.
    Did you have a bad experience in an Apple store once ? Did Steve Jobs not return your email ?
  10. #60
    Adelaide hills, SA
    I think that this thread has no further purpose, so I pronounce it as closed!
    If you don't like the radio in VAG cars, do what I did in my T5, replace it with the brand and cables you like.
