Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 60
Thread: It's time for a major overhaul of Skoda (and VAG) ICE systems
    Jan 2008
    Quote Originally Posted by 77kw polo TSi View Post
    Your missing the point.
    The RNS 510 interfacing through the MDI is hindered. It is possible to stay within the law and offer Video on the move. Jaguar, Land Rover do it.
    The RNS 510 offers a consistent interface no matter what you are doing with media. It's not possible to offer video on the move where the driver can see the screen and this applies to other vehicles as well.
    Whether your in the majority and like apple products (maybe not their closed systems) or like one of the 'smaller' players - there are more modern solutions out there.
    You can use the Analogue in and use whatever device you want as the interface.
    USB can take analogue - always has been able to - just look at VOIP headsets and dongles with A2D converters. The issue is the MDI is not a true MEDIA interface - just a MUSIC interface - big BIG difference.
    USB is DIGITAL only, it has 4 connectors - 1 5v, 1 ground and two for digital signalling and there is no provision for analogue on this cable without having to an Analogue to Digital conversion which requires some electronics and doing the same on the other side to convert that Digital back to Analogue which is absolutely pointless and reduces the quality.
    The MDI is a MEDIA interface because it can handle Analogue and Digital on the one connector and allows multiple different devices to connect to it, just because it doesn't handle video doesn't mean it's not a MEDIA interface.
    Both Andriod and Apple have far better, more intutitive UIs - for me the hinderence of the RNS510 UI is a big shame. The lack of true deliverable user features - like tagging multiple entries, swiping the screen, and choice of settings is a shame.
    More intuitive is debatable and is tagging multiple entries, swiping the screen and many choices of settings really that smart to do when you're supposed to be driving? Why do you think the RNS 510 and other headunits all have a clean interface with large buttons and easy to read text? And as I said earlier there is nothing stopping you using whatever device to be the interface to the headunit.
    Imagine - diary reminders popping up on the RNS screen (google or apple - who cares), where the appointment location is then optioned as a 'go to' for the GPS.
    Imagine an RNS that 'talks' to your home WiFi network (PC or MAC who cares) and updates the HDD remotely with your latest music and preferences.
    imagine not needing an SD card or USB stick to transfer content / data from one device to another.
    How hard is it to pull our a usb stick, sync it in your computer and reinsert it? You can already put POI's and so forth on the RNS 510 via SD card and the RNS 810 already has google integration (not to the level of the A.
    why couldnt one RNS 510 device swap content with another bluetooth device ?
    Copyright reasons for a start. And the bluetooth is not built into the RNS 510 so it would have to go through a digital to analogue and analogue to digital conversion.
    why could the RNS 510 not keep a cookie trail of where you have been (location, distance, speed etc) and feed that back to your home wifi network -
    You mean like the iphone data logging? Have you given any thought to the privacy issues that this raises? If someone wants this feature they can add it onto their car for under $100.
    Jan 2007
    Quote Originally Posted by Maverick View Post
    Most of them have problems as well. VW used the Apple specifications for the interface and Apple change these from time to time with different firmware (and sometimes hardware like the charging issue).
    Really?? The ones I used had USB ports and they all just worked. No legacy cables....etc. Just works. Units I have sampled recently were by Hyundai, BMW, Volvo and Holden. The point remains - how do they get it right and VW can't?
    Because not everything is capable of being connected to a USB port. How do you route an analogue signal through a USB port?
    Perhaps VW can come up with some oblique and expensive legacy cable for that. You mean to say there are some VW's that don't have an analogue port but do have MDI? Eek, another example of the validity of this thread.
    The MDI connector is designed to be able to accept analogue and digital in the same connector, for example a usb flash drive is a pure digital connection, the ipod on the other hand is a combinations analogue for the audio and digital for the control and not to mention is provides power (how does 6 wires attach to 4 connectors for a start) and the audio input is pure analogue.
    OK, I understand this. They are trying to avoid putting in an analogue port in. Both our newish VW's have an analogue 3.5mm port anyway so that negates the whole analogue via MDI thing. Again - other manufacturers seems to make this work well.
    This same connector can after a firmware update be used with other devices that come onto the market through a new cable.
    Not sure how this is unique to VW or MDI. Another null point.
    Believe it or not but the world does not revolve around the iTurd/iCrud/iPoo and VW are not going to create an interface that only work with these devices.
    Yet, other manufacturers can. This is kind of the point.
    For VW to connect to the ipod via a digital connection would require the MDI to have an authentication IC (for DRM reasons) so that the iWhatever can play back their music over the digital interface.
    It must be easy. Why can't VW do this?
    If this changes at some point the playback will stop so why would VW want to take that risk? Instead they offer a system that offers choice and don't force people into a proprietary expensive solution of having to use a iTurd/iCrud or iPoo.
    Funny you mention how you mention a proprietary expensive solution in a thread about how the MDI system is a proprietary expensive solution.
    Horrible in what way? Because it works and is legal to use when driving? VW are working within the confines of the Apple specifications and requirements.
    This thread applies for other devices too. Why should I have to buy a proprietary cable for each of my devices, whether it be a USB stick, iPhone or Android. The point is, every other car I've driven recently allow you to take your device straight into the car without a silly over priced extra that is fiddly to remove. It's just a poorly designed setup.
    Jan 2008
    Quote Originally Posted by brenno View Post
    You could at least try and get your facts right.
    BMW have a multitude of options which work with different types of headunits and operate in a different fashion. MY2011 onwards allows you to plug in the ipod using the USB connector alone but plenty of owners have kept using the Y cable of all the previous model BMW's as it gives a nicer sound. The Y cable is the same style split USB/Audio cable that Hyundai use.
    Hyundai requires their specific cable which retails for $110.
    "** Non Hyundai supplied iPod cable may not offer full operational control from the vehicle audio system. Please ask your dealer for further details and to confirm specific iPod model compatibility."
    The cable on the Hyundai plugs into the USB for power and control and the aux in for audio. So much for the far superior system! BTW this is the only way that Apple allow you to control an iWhatever, any other ways are not supported and will likely stop working at some point.
    From the manual
    "✽ NOTICE FOR USING iPod
    DEVICE
    • Some iPod models might not support
    the communication protocol
    and the files will not be played.
    (iPod models supported: Mini, 4G,
    Photo, Nano, 5G)
    • The order of search or playback of
    songs in the iPod can be different
    from the order searched in the
    audio system.
    • If the iPod crashes due to its own
    trouble, reset the iPod. (Reset:
    Refer to iPod manual)
    • An iPod may not operate normally
    on low battery.
    CAUTION IN USING
    iPod DEVICE
    • You need the power cable exclusive
    for an iPod in order to operate
    an iPod with the buttons on
    the audio system. The PC cable
    provided by Apple may cause a
    malfunction and do not use it for
    vehicle use.
    • When connecting the device with
    an iPod cable, push in the jack
    fully to not to interfere with communication.
    • When adjusting the sound effects
    of an iPod and the audio system,
    the sound effects of both devices
    will overlap and might reduce or
    distort the quality of the sound.
    • Deactivate (turn off) the equalizer
    function of an iPod when adjusting
    the audio system’s volume,
    and turn off the equalizer of the
    audio system when using the
    equalizer of an iPod.
    When the iPod cable is connected,
    the system can be switched to the
    AUX mode even without the iPod
    device and can cause noise.
    Disconnect the iPod cable when
    you are not using the iPod device.
    • When the iPod is not used for the
    audio system, the iPod cable has
    to be separate from iPod devies.
    Origin display of iPod may not be
    displayed."
    It's another example of nothing, the MDI is designed to be used for analogue input.
    It's called future proofing, the MDI connector is designed to work with a wide range of products through cable upgrades instead of head unit or MDI upgrades.
    How is it not unique to VW? Volkswagen have without a doubt one of the best collection of headunits of any car manufacturer. They have created a set of headunits that work in different brands, can be swapped across different models and even retrofitted to previous models. The UI is the same across the board and they have a modular design. Every other manufacturer has a mismash of headunits sourced from different suppliers with no commonality with other models. The MDI is designed to be independent of the headunit and has firmware upgrade options along with different connector options plus the MDI allows you to place the unit where ever you want without having cables hanging out of the front of a head unit as some brands required.
    Because it's not supported by Apple as I said, Apple only support a analogue interface which HAS to be via a cable that has more then 4 connectors, it CANNOT be via a USB cable as you require POWER (2 connectors), CONTROL (2 connectors) and OUTPUT (2 connectors). Reverse engineering and using the authentication IC can and will see the system stop working when Apple decide to change the way the authentication works.
    Errr it's pretty simple. If Brand X creates a headunit and builds an authentication chip into it and Apple change the way this operates you can no longer connect an Apple product unless they are running the old firmware or the headunit is replaced. With the MDI which correctly follows Apple specifications this is not a problem.
    You don't have to buy a proprietary cable for each of your devices, you can choose to use USB which is standard or you can use an analog input. It's only a poorly designed setup if you are unable to comprehend how the interfaces work and make wild baseless claims about other manufacturers which are plainly BS.
    Jan 2007
    Not the one I tried. Edit: 2008 model.
    Quote Originally Posted by bmw.com.au
    The USB connection in the central console can also be used to control mobile phones and Apple iPhones™ directly. If a suitable snap-in adapter is available for your mobile phone, you can connect and charge it in the central console using the extended connection of the music player in the mobile phone option. At the same time, the phone is connected to the vehicle’s external aerial and the quality of reception is audibly improved. Connecting an Apple iPod™ or iPhone™ is simple and straightforward using the original Apple USB cable.
    Quote Originally Posted by hyundai.com.au
    BluetoothTM connectivity allows safe handsfree telephone use and audio streaming with a compatible device. Full iPod® integration (via the USB port) allows customers to connect using their original iPod cables, conveniently making operation possible via the head unit.
    Not really required is it? I already have an analogue input port.
    A better example of future proofing would be to use a widely used USB port, and not a legacy port. Seriously.
    You said that having the MDI port makes it possible to upgrade the firmware. I really don't see the advantage here. You could easily do the same via a USB port. Besides, if I wanted to do an upgrade with the MDI I wouldn't be able to due to the proprietary cable that VW requires you to purchase before doing so.
    Yeah yeah.....you said all that previously. Why does it work in other cars though? This is the bit I want in my VAG vehicle
    Aah, so all of a sudden it's not possible to update the firmware of any other manufacturers head unit. It's only possible on VAG cars with an MDI. Got it.
    Sorry, did you just say that I don't have to buy a proprietary cable in order to use USB?
    Of course I can use analog inputs, but seriously, I had analogue inputs on a VW in 1993. I'd like something a bit more up-to-date now.
    I want to be able to take my Android or iOS device, whatever tickles your fancy....no misguided hate or angst here, and plug it into the car with the supplied cable, and it just works.
    What I *don't* want to have to do, is get home after having a new car delivered to me, and realise I have to go back to the dealer, and buy different over-priced cables and have to swap them around (which is a real pain in the arse) whenever I want to change my device. It's a poorly designed system for those with multiple devices, and that's one of the key points by the OP in this thread.
    You could at least try and get your facts right...
    ...if you are unable to comprehend how the interfaces work and make wild baseless claims about other manufacturers which are plainly BS.
    Hey Mav . . . making a comment on the forum does not mean replying with twaddle and BS remarks.
    You're obviously a fan of early 2000 technology priced as hi end stuff. And I can read your keen on old fashioned interfaces and worry about copyright on suggestions of future features. But I'll bet there are others out there that think it healthy to debate what could be and what might be. Hang in there.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Adelaide hills, SA
    Majority of the owners are obviously happy, since only 3 people complain. Talking about a healthy debate? Maybe instead complaining, you should tell us which product is better and perhaps get it instead of RNS510.
    I honestly wouldn't want the similar interface to iPhone gear in the car.
    Nov 2009
    Perth, WA
    I don't think you guys are understanding that there is no way to get audio streaming from an iPod/iPhone just by plugging it into a USB port.
    The USB specification doesn't support streaming audio, and there is a reason why the apple connector has more pins than a USB cable.
    Jan 2007
    Quote Originally Posted by pat25d View Post
    Yet I can charge, control and stream music via the USB port on numerous other vehicles.
    Nov 2009
    Perth, WA
    Which vehicles?
    You can't even do that through a Mac computer.
    Jun 2007
    Sydney, Australia
    I still use CD's
    Flipper Dog
    Now - T-Roc R, Audi Q5
