Results 1 to 4 of 4
Thread: iPod connections
    Dec 2009
    Mt. Colah, NSW
    iPod connections
    OK so maybe I'm just too old to understand this new fangled technology....
    Recently swapped out the standard Eurovox head unit for a Sony with USB. Now when I connect my iPod to crank up some sensational Pink Floyd things seem to go a bit awry. I can't listen to all the songs. They just don't seem to be available. When I skip to the next song, it jumps forward several songs. I've noticed a similar thing when I hook the iPod up to other USB devices like the TV. Seems to be something about a folder structure.
    Anybody seen this? Have a solution? Sure I could just use an aux cable, but then I have to selct songs through the iPod and not the stereo.
    Feb 2008
    Richmond, VIC
    There is a difference between an iPod adaptor and a standard USB conection.
    thats probably where things are going wrong.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by steve_tdi View Post
    I think Steve is on the money here, USB connections are either "iPod compatible" or not. Those that are not will simply see iPods (but not iPhones or iPod touches) as a memory stick and play whatever files it sees in whatever order it sees them.
    *most*... current head units I would have thought would be iPod compatible if they had a USB, but it sounds like that isn't the case so it looks like you might be out of luck.
    Dec 2009
    Mt. Colah, NSW
    Yep that's about what I expected. No problem, thanks guys.
