Results 1 to 10 of 11
Thread: iPhone 3.0, Bluetooth audio, and RCD 310
    Jun 2009
    Perth
    Anyone manage to get this working? My iphone is paired with the RCD 310, but it doesn't want to stream the stereo? - it works fine as a mono headset for calling, but not for stereo audio.
    - The basic bluetooth option with RCD 310 should be able to do a2dp stereo right?
    Jan 2009
    brisneyland
    No, it can't.
    "One art please!" --->http://benno.redbubble.com
    Jun 2009
    Perth
    You mean the $700 bluetooth option - that DOESN'T COME with a2dp bluetooth audio? , only the premium does?
    Jan 2009
    brisneyland
    AFAIK the basic BT does not do A2DP.
    Feb 2009
    Is A2DP now enabled with the latest iphone update?
    Will have to test it on my kit, but bluetooth audio is pretty yuk anyway (and wastes your battery i assume) - i'd look at getting an ipod kit/cable, or burn some cds
    Jun 2009
    Perth
    Any luck??? The RCD310 pairs fine with a nokia, and stream bluetooth music well, but CAN'T DO IT WITH MY IPHONE... Anyone manage to make it work with iphone?
    Feb 2009
    Quote Originally Posted by whitford View Post
    Mate, your RCD310 does not have bluetooth, so can't pair with anything. Your phone pairs with your Bluetooth kit, not the RCD310.
    Please clarify which BT kit you have. You say your Nokia streams A2DP to it?
    I have streamed A2DP from my iPhone 3G 3.0 but it's crap. Sound is awful, it is a pain in the ass to control, and jumps occasionally.
    Jun 2009
    Perth
    My BT kit is the basic $700 kit - dealer fitted. It streams A2DP stereo from my nokia fine, but not from the iPhone. And my iphone streams audio fine (I've got an av receiver that can do BT, and it streams fine from my iphone).
    My RCD DOES have bluetooth.
    Feb 2009
    Well it is unique if it does.... but you obviously know best.
    RCD310 does not have BT built-in. They can be integrated using either factory installed or aftermarket BT systems, but the system itself does not have BT.
    How do you make the Nokia stream A2DP as the $700 VW BT system does not have any controls to start / stop that?
    Jun 2009
    Perth
    Look, the RCD 310 basically:
    - In the setup menu: BLUETOOTH AUDIO: On / Off.
    - If you switch them to "ON", then I can stream my Nokia to the unit - as well as receive phone & answer the phone from the steering wheel.
    - You play & stop from your phone and not from the unit.
    I mean, it's not that I need to use the bluetooth function, but just want to get them working.... For my day to day music, I connect the media-in kit to a 320GB hard drive, and control & browse the music from the RCD 310. Just curious why it doesn't work with my iphone.
