If its just factory stereo and a of the shelf amp then it will need to have a line in connection or you will need to get a Line out to RCA converter as the factory stereo has no RCA outputs
Do a search and look in the audio section for more info.
Just though I'd make a thread as I couldn't find one.
My friend bought a subwoofer and a amplifier, but im wondering if it is really as simple as wiring it in as you would, in other cars, or are there codes that need to be delt with ?
Any help with this would greatly be appreciated especially if you have or know someone who has installed either 1 or both of those things.
Thanks
Kay
Just forgot its a 90tsi
Also sorry if it's a dum question, but I come from a older generation golf
Garage:
VR6
XR6
R36
The factory deck also has no remote power wire for the amp either. I used the power wire from the ciggie lighter to make it turn on but remember to put an inline on/off switch in too other wise the amp will always be running whether the deck is on or off.
Forever blowing bubbles.
The deck should have two power wires running to it. one is constant and the other will be +12v with ignition on. Use the later to tap In for the amp remote wire that way you won't need a Switch. If you can get hold of a multimeter to check which has voltage when ignition of and what has volts itch ignition on. Or get hold of the wiring diagram..
