Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 91
Thread: Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6
  1. #51
    The only thing that is still a little mystery is the operation of black pin5 to Yellow 11 on the Mk7 which is marked as green on your wiring diagram (my harness had a grey wire). It could be for button illumination perhaps but I'm not 100% sure.
    Tiger73: You sure do ask the big questions!! I''m not entirely sure what the green wire from PIN5 (J453) to PIN11 (J527) does. In fact, I suspect that this wire may not be there on a mk7 (notwithstanding what the Wiring Diagram says). Here is PIN-OUT for connector 5k for J453 - notice the glaring absence of a designation on PIN5!!
    Don do you have DSG paddles in your car? I know of a wheel that could be going cheap if you're up for it!!!!
    Best offer that I have had in a long time, but as marcrae19 is insinuating, perseverance in adversity is either the hallmark of a very committed person, or it's a sign of a person that should be committed (to somewhere where there are lots of behavioural therapists)! - As I suspect that you fall into the former category, I will reluctantly decline the offer - but thanks
  2. #52
    That is interesting. I guess it's an optional item. Surely they wouldn't put a wire there for no reason.
    In the Mk6, pin5 is use to retransmit the horn.... but the horn is also connected into pin4. I've wired it this way to the Mk7 steering wheel also and the horn still works
    The reason I got the wheel was because it came up at the right price. I don't mind spending a bit of time to get it working, however it now looks almost certain that I'll probably have to spend half as much again and there's still no guarantees the additional parts are going to fit/work.
    It's probably better for someone with a Mk7 to take it off my hands and fit to their car. It's a nice upgrade for someone looking to get some DSG paddles.
    That way I can get a complete Polo/Scirocco wheel instead and not have to worry that all the bits are going to fit/work.
    May 2015
  4. #54
    Nice find marcrae. I have no doubt it can be done, however I still suspect these wheels are all for PQ platform not MQB.
    Well I found out that the buttons from a Polo GTI wheel was going to cost me $600 at the dealer with no guarantees it was going to fit/work and no returns on the part so I've sold the wheel and will go on the hunt for a Polo GTI/Scirocco R/Mk6 GTI or R wheel with paddle shifters.
    I'll do some research on the Polo steering wheel as I'm 99% sure that's what the guys in the UK that claim that they have working are using.
    May 2015
    I hold out hope that someone much smarter than I will figure out how to do this. In the meantime i will keep adding information i find related to the topic.
    Here i found this steering wheel control module table. Not sure if it's of any use.
    Steering Wheel Control Module Versions - Ross-Tech Wiki
  7. #57
    Feb 2008
    ACT
    Our Mk7 wheel arrived this week, so I'll try to pull it apart in the next few weeks and do some comparison with the Mk6 wheel in terms of the CAN and LIN traffic.
  8. #58
    May 2015
    Awesome James. Does your Mk7 have the volume buttons on the left hand side? Does it have paddle shift? here is mine
    Attached Thumbnails Attached Thumbnails Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6-mk7rmfsw-jpg
  9. #59
    Just don't tell me it was something simple once I've sold my wheel!!!
    Feb 2008
    ACT
    Quote Originally Posted by marcrae19 View Post
    Yes to the volume buttons, no to paddle shift - it's from a manual Mk7 Golf R.
    Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6-20150907_183026-jpg
