Results 1 to 10 of 91
Thread: Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6
Threaded View
    Having a think on it overnight it may be that the simplest way of getting this steering wheel going is to replace the buttons/controller with ones from the latest Scirocco - which has the same look as the Mk7 but has the buttons from the Mk6.
    My hope is that these buttons would fit into my new Mk7 wheel.
    The risk with these sorts of retrofits is always compatibility of hardware. Without some equipment to decode the LIN signals to determine what button press causes what message in both mk6 and mk7 button controllers (module in the steering wheel that generates the LIN messages), it's a little bit of guess work. I now suspect that the people that have this working either have a newer version of SWCM or have somehow jagged a Mk7 steering wheel that is backwards compatible with the Mk6 SWCM hardware.
    For others reference the hardware I have in the Tiguan is a highline module. Scan details as follows:
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90440LGB0001F
    Coding: 1892140000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_SE36.rod
    VCID: 76CD31ABC973E38E7F-8023
