Originally Posted by
tigger73
The only thing that is still a little mystery is the operation of black pin5 to Yellow 11 on the Mk7 which is marked as green on your wiring diagram (my harness had a grey wire). It could be for button illumination perhaps but I'm not 100% sure.
Tiger73: You sure do ask the big questions!! I''m not entirely sure what the green wire from PIN5 (J453) to PIN11 (J527) does. In fact, I suspect that this wire may not be there on a mk7 (notwithstanding what the Wiring Diagram says). Here is PIN-OUT for connector 5k for J453 - notice the glaring absence of a designation on PIN5!!
tigger73
Don do you have DSG paddles in your car? I know of a wheel that could be going cheap if you're up for it!!!!
Best offer that I have had in a long time, but as marcrae19 is insinuating, perseverance in adversity is either the hallmark of a very committed person, or it's a sign of a person that should be committed (to somewhere where there are lots of behavioural therapists)! - As I suspect that you fall into the former category, I will reluctantly decline the offer - but thanks
